1990 Ford Mustang LX Hatchback,
302cui, 5.0L v8, w/ T-5
IGNITION:
MSD digital-6 plus ignition box
MSD 8.5mm super conductor spark plug wires, w/ msd seperators
MSD blaster 2 ignition coil
MSD pro-billet distributor
MSD cap/rotor
MSD tfi module
FUEL:
Ford Racing 24lb Hi-Flo fuel injectors
BBK billet adjustable fuel pressure regulator w/ liquid filled guage
BBK 190LPH in-tank fuel pump
ENGINE:
Ford Racing B303 camshaft
Ford Racing 1.6 roller rockers
Granatelli 75mm Mass Airflow Sensor, chrome, w/ CAI tuning
Professional Products 70mm Throttle body
Professional products 70mm EGR spacer
BBK chrome fenderwell CAI kit
Trickflow street upper/lower intake manifold (upper being polished)
Trickflow twisted wedge cylinder heads Fully CNC Ported & Polished w/ race valve job
Trickflow 1" intake spacer
DRIVETRAIN:
Centerforce Dual friction clutch
Centerforce throwout bearing
Ford racing aluminum driveshaft
Unknown short shifter
Ford racing billet steel flywheel
Ford Motorsports 3.73 gears
COOLING:
Mr Gasket 160* thermostat
Granatelli Motorsports aluminum radiator
Redline water wetter coolant
Flex-a-lite 'Black Magic' electric fan
Jegs super-duty chrome waterpump
MISC:
Powermaster 140amp chrome 1-wire alternator
Professional products street harmonic damper
Jegs polished, sealed battery box w/ wire kit for hatch relocation
Optima yellow top battery
CHM clutch quadrant and cable
Steeda clutch firewall adjuster
EXHAUST:
Hooker longtube headers
Custom xpipe, 2.5"
Flowmaster 2.5" american thunder mufflers w/ oem tailpipes
not yet reassembled. everybody tells me i should dyno 300+rwhp without a problem.
will be dynoing & getting custom burned chip when its running.
sometime down the line i will get a custom grind cam, and ill have to change the springs on my heads probably, hopefully pick up decent power from chip & cam
derek
