  • 1994 - 1995 Specific Tech
3000GT vs. 95 GT
  • Thread starter Thread starter burtieburns
  • Start date Start date Apr 7, 2004
  • 3
1 of 3 Next Last
burtieburns
32
Beavercreek, Ohio
Apr 7, 2004
  • Apr 7, 2004
Do you think a 95 or 96 3000GT Twin Turbo manual would be a 95 GT, with 3.73, T56, pullies, C&L cold air, and Dr.Gas off road x with a dynomax catback.
P
ponypowa
43
  • Apr 7, 2004
Vr4
Vr4's rape dude, I think you would need more then that... just stock vr-4s are fast.... My friend had a vr-4 with a diablo kit on it, 200+ top speed, the thing was unstopable
burtieburns
32
Beavercreek, Ohio
Apr 7, 2004
  • Apr 7, 2004
The only plus to it all is the guy can't drive.
Ryan Paterick
943
  • Apr 7, 2004
Off the line, it would be close, but after awhile the 3000 would pull on the stang. My GF has the 3000gt sl and it's a turd off the line. I would say the vr4 has a little more guts off the line though.
Dave95GT
bAd mUtha
477
Looking for all of my missing posts
Apr 7, 2004
  • Apr 7, 2004
3KGT VR4's arent that fast. They weigh close to 4000lbs and run a low 14 stock
burtieburns
32
Beavercreek, Ohio
Apr 7, 2004
  • Apr 7, 2004
i didn't think they were horrible fast cuz of their weight but i know they r quick
ProKiller
3,064
15
78
PA
Apr 7, 2004
  • Apr 7, 2004
saw one at the track before. wasn't impressed. it had some bling on it . i don't know about the engine but it was only running like mid 14s. the good thing about those drag racing is that they are ment for road racing. 4-wheel drive is a hinderance on the strip. i'm assuming your talking about yourself right burtie? i think you will get a good lead off the line, but they do make good power towards the end. i think you'll beat him, it will be close towards the end, but you'll prolly come out on top.
mustangramair
326
Iowa
Apr 7, 2004
  • Apr 7, 2004
I saw one pull a 14.6 at the strip
KingDiamond
637
Chicago, IL
Apr 7, 2004
  • Apr 7, 2004
A guy I know ran high 13's with his stock 95 VR-4 and I'd say he was a fairly good driver. But if you said the driver isn't that good then you should be able to take him in the first 60 mph.
R
RyClef331
118
Jacksonville,NC
Apr 7, 2004
#10
  • Apr 7, 2004
  • #10
uh....huhuhuh. You guys are completely missing the two most important factors. He may suck ass at driving but he doesn't have to worry about the launch (except bogging) with AWD. If is good enough to build boost before letting the clutch go...you're done for the first 100ft. I think that you can play catch up though and get him. He may say his car is stock but a simple $10 bleed valve between the wastegate and its signal hose is all he needs to crank the boost up and still say "Its stock..." Watch him off the line. My roommate has a 1991 Eagle Talon TSi AWD with stock everything except for a clutch and the home made boost controller and it will rip off a 1.70 60ft time on crap all season tires. The sick part is he can duplicate that time at anystop light on the street. The car has been 14.01's with a GAWD awful clutch...hence the new clutch. Easy 13s out of an other wise stock DSM. That vr4 maybe a heavy bitch but if has the boost going off the line, he'll get the power to the pavement while your doing a smoke show.
Black95GTS
1,644
Marlborough, MA
Apr 7, 2004
#11
  • Apr 7, 2004
  • #11
i agree with ryclef, if he knows enough to spool the turbos before he launches you're gonna be playing catch up, and you better catch him quick before your tq advantage goes away... I think its doable w/373s if you shift and launch well. I'd let some air out of the rear tires. I would NOT race him at a roll, he'll pull on you. VR4 TTs are fast as hell in the top end.
Gravel
216
Bellingham WA
Apr 7, 2004
#12
  • Apr 7, 2004
  • #12
Couple of good hard launches and he is going to break the output shaft for the rear transfer case anyhow...
I have said it before and will say it again, its the Anna Nichole Smith of awd performance cars...
BTW I also own one, its really not that great!! All kinds of fluff but way too heavy to make it worth while.. Over 4k lbs with driver!!
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 7, 2004
#13
  • Apr 7, 2004
  • #13
Smoke show? If you leave that crazy in a stang then I will beat you off the line with my 10-Speed Huffy....you need to re-think your launching techniques if you see smoke but i hope that no one leaves that hard unless they have slicks/drag radials and then its never a smoke show....
I agree though, those AWD cars do have a crazy launch but a Stang doesn't automatically mean a smoke show. If you can launch your stang then you should be able to keep with them somewhat right off the light.
W
wg3497
11
#14
  • Apr 7, 2004
  • #14
I had a '93 Stealth R/T TT before I bought my '94 GT. There's no contest. The Stealth is SO much faster. I never took it to the track, so I don't have any solid times. It doesn't take much to get the turbos going and then it's nothing but crazy acceleration until you let off the gas. You just have to hope nothing breaks on them, cause they are spendy and a pain to work on.
Steeda90GT
714
Central Jersey
Apr 7, 2004
#15
  • Apr 7, 2004
  • #15
I say if he knows how to drive, he'll take you (providing his car doesn't fall apart in the process)
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Apr 7, 2004
#16
  • Apr 7, 2004
  • #16
My opinion: should be a close race, depending on traction. The 3000GT has good power, but it weighs 600 pounds more, and the AWD is probably killing 10% more horsepower than your driveline does. Power to weight ratio suggests that all else being equal, you should outpower him. That'll be less true the faster you go.
cb18201
1,140
CT
Apr 7, 2004
#17
  • Apr 7, 2004
  • #17
i think he will most likely beat you, dont under estimate those cars because of their weight, i think the two turbos well make up for that. my friend has one an it is real fast
WhiteDevil
2,717
San Diego
Apr 7, 2004
#18
  • Apr 7, 2004
  • #18
That is a tough one i have seen modded ones go fast A.K.A. 11s. But most stock are in the low 14s so i say it will be a close heat but the stang might just edge it out.
P
ponypowa
43
#19
  • Apr 7, 2004
  • #19
My friend had one with a diablo kit on it, ran 10's geared for top end... if it was geared lower possibly 8-9, it is mighty quick with mods
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Apr 7, 2004
#20
  • Apr 7, 2004
  • #20
I think you're talking about something different. I'd guess the "11's" comment from WhiteDevil was referring to *quarter mile*, not eighth .
  • 3
1 of 3 Next Last
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
95 GT Convertible fuel system
  • Performance_nube
  • Jun 28, 2024
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2024
Performance_nube
