mikethebike
Because my machine shop has had a rash of them since they came out. And they said it starts to get a little thin for street driving at .060. Not that it can't go farther. You can do a 347 also, but the pistons are deadly close to being out of the bottom. That shop won't even assemble a 342 in the new blocks because the skirts are so short.They have another over there right now. i'll see if I can steal some bore thickness measurements from them
Why not intall a silicon impregnated nickel sleeve?
( I run an aftermarket block, made by Ford, no grinding here.)
the bores are shorter, but just because Ford disigned it that way so you dont have to notch it, I would have left the bores longer for more piston skirt support, even with a notch in the bore it would have added more support.
