302 cam in a 351w???
the cam determines the firing order, not the crank. why would the f cam have a 351 firing order when its in a 302? in that case i am wrong when i said it would fit cause i thought 351 had the same order. but don't 351's have the same firing order as a 82 or later 302?
in 93-94 is when ford put out the rollor block that had the spyder bolt down holes tapped for threads. the earlier 351w blocks had a smaller base circle cam and needed a retrofit cam package to work right or something. the rollor ready blocks had a f4te casting number by the starter on the block.
the rollor 302 has the same firing order as the 351.
