302 efi convert to carb
gofastbrett
I have a 88 notch and have a 302 with the efi out of a lincoln. I want to put a 351w in but was wondering if the 351w upper and lower intake would fit on a fuel injected 302? And would I be able to turn a fuel injected 302 into a carburated motor by replacing the efi to a 4 barrel manifold with a carb and not have to do anything to the bottom end? Thanks
the 351w lower intake is wider than a 302. however, the upper manifolds are interchangable. you can make a 302 carburated without doing anything to the block. just bolt a 4 barrel intake and carb on it; again, the lowers are different size so make sure you get one for a 302.
