I have a 1970 D0oE Engine/ Heads. Can not tell if heads have been reworked.
Car ran great until I tore the top end off to find out what kind of cam and lifters it had. Discovered that every push rod was severely bent. Car ran strong, did not burn oil, but ran a little too rich and had a tendacy to stall out
unless I put the car in neutral.
I also discovered that the engine had been bored over .030 (as stamped on the TRW L-2249 piston tops). I pulled the cam, but I could not find any manufacturers identification. The only numbers stamped to the cam were "1206".
Here are my questions???
1. Do I need to pull the engine and tear out internals to eliminate possibility of metal shavings. (found none in oil pan)?
2. Do I need to determine all the crank measurments to determine which type
of cam, lifters, rockers to install?
3. Are the TRW L-2249 pistons to hifgh of a compression for this block.
4. What is the best combination of cam, lifters,rockers for this engine for street use and ability to drive long distance?
5. Best place to buy rebuilt engine should I need to get rid of this one?
