302 rocker arm ware
Ewok302
Texas
Hey guys I needed some help to verify if my theory is correct. So I goofed up and installed both intake gaskets on one head only and ran it for about 30 minutes it idled perfect but once you took the oil cap off It ran like crap and made huge vacuum in the valve covers . So I understand what the problem was intake “leak” but what I’m wondering is could I have sucked the oil from the valve train ? Because after letting it run I begin to have valve train noise turns out the pushrod pushes pretty deep into the rocker causing too much gap I replace the rocker with one I had in the pile and the noise went away but not more then five minutes into running it’s starting to do the same on the opposite head . I have installed new intake gaskets and want to know if you guys think my rocker problem will stay away , like can the excessive valve cover vacuum really cause my issue ?
I doubt your gasket incident has anything to do with the loose rocker problem.
Stock rocker arms?
Did you remove rocker arms, or mess with the valve train at all before this issue?
What is your oil pressure?
