hi
i thinking to build 302 with vortech v1 \ v2 super charger .
the engine is 302 ho 87
i use E7TE iron head
cam : CCA-35-306-8
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,000-6,000
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 230
Duration at 050 inch Lift 224 int./230 exh.
Advertised Intake Duration 284
Advertised Exhaust Duration 290
Advertised Duration 284 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.533 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.544 in.
Valve Lift with Factory Rocker Arm Ratio 0.533 int./0.544 exh.
Lobe Separation (degrees) 114
stock rods and crank
cr 9-9.5 /1 (new forgrd piston)
arp bolts
and i thinking to boost 9-11 PSI
this is will work sefty ? ( with out broken the block )
how mach hp i wil get ?
cam : CCA-35-306-8
arp bolts
