OK. I just bought a 1969 Fastback with a stock 302 and a 2 barrel carburetor. I tuned it up with new plugs, wires, cap/rotor, points/condenser, hoses, belts, and changed the oil. It ran fairly well prior to the tune-up.
It will idle real well for a minute or two and then suddenly die as if I turned the key off. I have adjusted the points to .019" gap. It runs very smooth until it dies. Could it be a carburetor problem, the voltage regulator, vacuum, etc...?
It will also do this as I asm driving. I was puttering around the neighborhood at a steady speed of 25 mph and it suddenly died a couple of times. What could it be? Thanks.
