302 timing cover problem
Falcon79
214
Dallas, TX
Hi guys,
I'm trying to change out the timing cover on my 1991 roller block so that the dipstick is located in the front and also so a mechanical fuel pump can be installed. To do this I have a timing cover from a 1966 289. My problem is that there are two alignment pegs coming out from the block that keep the older timing cover from sitting flush to the block. Should I drill the old timing cover or should i try to take the alignment pegs out? Any help or advice would be appreciated.
Those guys just pull out with a pair of pliers, they aren't "pressed in" or anything.
Make sure and install a new crank shaft oil seal before you put the new timing cover on the car, and put a very light coat of oil around the contact area before you slide it on the snout.
Also, use RTV at the corners to help prevent leaks.
Also, that is one crappy looking timing gear set up.
Are you thinking about replacing it while you have it all apart? Or is it new already? What kind of oil do you use? Is it a metal gear, or that crappy nylon thing?
And I see you have the two piece fuel pump eccentric.
I'm not really sure how the two are different, but it may become relevant to your project.
Can you explain that a little more, not sure i get what you are saying, this is my first time dealing with this stuff.
Those alignment dowels do exactly that: align the cover so the front seal fits the dampener evenly all the way around. So, if the alignment dowels aren't there, just use the dampener as the aligner, ie, before tightening the cover, slip the dampner on the crankshaft and allow the cover to 'float' around it and align itself.
Hope I didn't make things too confusing.
What oil do you use, how often is it changed, and how is the car driven?
Modern oils have largely made sludge little more than a scare tactic to sell oil to uninformed people, but there are still circumstances that can promote its formation. Very long drain intervals do a good job as do short trips that don't allow the oil to come up to temperature.
I would say regular oil changes(~4000-5000mi depending on conditions) would eventually clear it out. Many say that synthetic oil gets rid of it very quickly, but can also uncover "hidden" oil leaks by dissolving the crud that plugged them.
