302 to a 331 ?
  • Thread starter Thread starter One91Fox
  • Start date Start date Jan 6, 2009
1 of 2 Next Last
O
One91Fox
28
Decatur, AL/Starkville, MS
Jan 6, 2009
  • Jan 6, 2009
What is the easiest and best way to turn a factory 5.0 302 into a 331?
O
One91Fox
28
Jan 6, 2009
  • Jan 6, 2009
From 302 to 331
What is the easiest/ best way to take a factory 302 that has a few modifications and turn it into a 331?
Didn't mean to post twice, computer messed up.
I
irish
168
Florida
Jan 6, 2009
  • Jan 6, 2009
Buy a 331 stroker kit, take both to a good machine shop, done.
Sell the 302 and buy a shortblock from Fordstrokers.com, done.
Matt
Brian@PAR
86
Phoenix AZ
Jan 6, 2009
  • Jan 6, 2009
Don't do it at all. Turn that 302 into a 347 using the same procedure as above.
T
tiptop
73
  • Jan 6, 2009
yep, give woody a call at ford strokers
O
One91Fox
28
Jan 6, 2009
  • Jan 6, 2009
Are all these recomendations coming from experience with these blocks?
QUICK91LX
968
New Jersey
Jan 7, 2009
  • Jan 7, 2009
This sort of thing has been done countless times with stock blocks...you can either go the route of purchasing the stroker kit and taking your motor along with the kit you buy to a machine shop who will do all machine and assembly work for you....or buy the motor in short block or even crate engine form from any of the various sources available...the Mustang aftermarket is huge. Do some research on heads, intakes, cams and all other various supporting mods for your project.
bynummustang
Seen my other Jackstand?
Jul 24, 2005
NC State University
Jan 7, 2009
  • Jan 7, 2009
Make sure you know why you have chosen 331 over other strokers. Research and plan your motor from oil pan to throttle body.
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,147
2,779
224
Vass, NC
Jan 7, 2009
  • Jan 7, 2009
If done for the right reasons, going with a 331 can be preferable to going with a 347. However, the majority of gear-heads will be better off going with a 347. They have 16 more cubes and therefore will make more power, all else equal.
As mentioned do your homework, plan out the entire build, pick a block and internals that meet your requirements, and then find a good machine shop that you have faith in. Determine how much you expect everything to cost, then set aside twice that and you'll be ready for the project.
Chris
O
One91Fox
28
Jan 7, 2009
#10
  • Jan 7, 2009
  • #10
So which would be better for a daily driven car that would see both road courses and drag strips? Possibly going to add a supercharger to the combo as well.
ShortThrow50
923
Pa
Jan 7, 2009
#11
  • Jan 7, 2009
  • #11
its easier and sometimes cheaper just to buy an already built stroker bottom end. i got my 347 shortblock built by woody at fordstrokers.com. if yor gonna do a blown 331 or 347, you should prolly buy a block that can handle the power and thats gonna run you almost 2k extra. IMO if you wanna go the blower or turbo route, you should just stay with a 302. If yor gonna go with the regular stock block n/a stroker route or any route for that matter i hope you have something other than stock h/c/i
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jan 7, 2009
#12
  • Jan 7, 2009
  • #12
O
One91Fox
28
Jan 7, 2009
#13
  • Jan 7, 2009
  • #13
What would be a better h/c/i combo for the 347 stroker than what I currently run on my 302?
Current h/c/i is ported stock heads, b303 cam, and gt-40 intake. I know that there are many other parts that are much better, but what are some individual opinions on what combo to run?
Bullitt347
I have been doing it wrong this whole time
4,015
3,005
204
Middle of Maine
Jan 7, 2009
#14
  • Jan 7, 2009
  • #14
AFR 185 heads, custom cam, Edelbrock Performer RPM 2 or Victor EFI (depends on LOTS of things) or even a TFS Intake. Do not forget bigger fuel injectors, Throttle Body, MAF...........ect............
ShortThrow50
923
Pa
Jan 7, 2009
#15
  • Jan 7, 2009
  • #15
i agree or at least spend 2400 on a tfs top end kit. you can substitude the stage 1 cam out for a stage 2 if you call summit. i run a stage 2. that kit is complete and flows close to afr 185 heads
O
One91Fox
28
Jan 7, 2009
#16
  • Jan 7, 2009
  • #16
If you don't mind me asking, how much power does your setup put out?
Brian@PAR
86
Phoenix AZ
Jan 7, 2009
#17
  • Jan 7, 2009
  • #17
Here is a suggestion
Rebuild the 302 using some light hyper pistons and put a set of RHS 200 heads, custom cam and a track heat intake on it. You'll make 425 at the flywheel N/A. The motor will idle smooth, not load up, and pull to 7K. Save your dough for an early, Mexican, or aftermarket block (BOSS 302 would work just fine) then do the 347 with the same parts but a new cam and make 550 N/A.
You could do the 347 in a roller block but you are pushing your luck at 550 and the tune is critical at that power level in a roller block.
Oh and IMO the only reason to do a 331 is if you are an inexperianced builder as there are some things that are "special" about a 347. Opinions vary on this subject but there are two things that are NOT a concern. Built right a 347 will not use oil and the rod stroke ratio is not an issue.
FastDriver
Sep 5, 2001
6,147
2,779
224
Vass, NC
Jan 7, 2009
#18
  • Jan 7, 2009
  • #18
Because it's not worth starting argument/long-winded-discussion #1423 on this subject, I'll just say that I completely concur with the bolded portion of this quote, and in the OPs case, there is no reason to build a 331.
Chris
reddog
11
#19
  • Jan 8, 2009
  • #19
If you want a stoker that will last.... go with the 331.. but don't go the cheap way out buy good stuff man!!! If its a pinks show, just buy something thats cheap or on sale!!!!
ShortThrow50
923
Pa
Jan 8, 2009
#20
  • Jan 8, 2009
  • #20
havent fired it up yet bro. its still on the stand. i will let you know when it goes to the dyno. the picture below was when i test fitted to see if the engine would go in with the lt headers attached. needless to say it di
1 of 2 Next Last
P
Engine Help 331 stroker
  • pdmount
  • Feb 19, 2026
Fox 5.0 Mustang Tech Feb 21, 2026
pdmount
P
Mustang 2 74’ Oil Pan Help
  • scaryfresh
  • Aug 12, 2026
1974 - 1978 Mustang II Talk & Tech Aug 12, 2026
LILCBRA
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
J
Resolved Ford 302 damper issue
  • James S
  • Aug 8, 2026
  • Other Auto Tech
Other Auto Tech Aug 8, 2026
James S
J
