jackchan
N/A Mustangs run in Pure Street at mid 10's on small slicks with unported heads, and .500 lift cams so yes it is possible to run 10's in a lighter focus. Why a focus.....might I ask? A mustang would be much safter because of its length. Length = more stability.
500hp and hold up with a stock block.....good luck! If it were me and I just had to do a Focus, I'd contact RICK91GT here on the board and get him to build me a stroker (man o war block) 347 stroker with AFR heads, about a
.568 lift solid roller cam, and lighten thruout. Slicks will get your traction, no problem if you can get the weight tranfer correct. IF you can't run 10's with that then you need to quit racing!
Jack
Jack
