302 with a t56
  • Thread starter Thread starter 65inworks
  • Start date Start date Dec 9, 2007
65inworks
101
sacramento,ca
Dec 9, 2007
  • Dec 9, 2007
What kind of t56 do i have to use to work with a ford 302 based block... what i mean is can i use a camaro or firebirds t56 with a different bellhousing? this is a new ballpark for me so any help is appreciated, thanks Nick
D
D.Hearne
11,730
south louisiana
Dec 9, 2007
  • Dec 9, 2007
I thought the T56 had an integral bellhousing............................
BarnStang
1,260
Hagerstown, MD
Dec 9, 2007
  • Dec 9, 2007
It does. You can change the front of he T56 case to change the bell, but gets expensive. I had the chance to buy a T56 out of a Camaro, but to use it in my Firebird project would have cost nearly as much as a new one withthe correct front cover plate. Can't remember what it's called. Call D & D performance and they can explain further. http://www.ddperformance.com/T-56 Transmissions.htm
Shakin66
628
Waycross, Ga / Lake James, NC
Dec 10, 2007
  • Dec 10, 2007
If you are interested in this swap it is easier than you think. I have a t56 in mine and love it. You will have to raise the tunnel up...Period. If you are not willing to do this it will not work. Any you'll need to look into a hyd. throw out bearing for clutch actuation. I have had mine for 2 years and am totally happy with it.
Call darkhorse for the crossmember & the tunnel patch and then email me (jamesleasing@bellsouth.net) if you want some ideas as to how to mate the t56 with an older toploader bellhousing.
G
Gailahan
144
St. Louis, Missouri
Dec 10, 2007
  • Dec 10, 2007
When I was looking into a T56 swap I was told that there was no way to mate a firebird/camaro T56 to a Ford motor. It's a shame b/c they are so much more abundant.
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
J
Resolved Ford 302 damper issue
  • James S
  • Aug 8, 2026
  • Other Auto Tech
Other Auto Tech Aug 8, 2026
James S
J
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
