306, 331 or 347 bulid up
Im gonna do an Art Carr build up.
Here are the parts:
EXTREME A.O.D.E.
#22251 Super Rebuild Kit $299.00
This kit contains all the friction plates & steel plates needed to overhaul the transmission. Contains a complete bushing kit, bearing kit, filter, gaskets and seals. The common complaint with the AOD is premature failure of third gear. To cure this we upgrade the direct clutch pack with Raybestos Blue Plate Frictions & Mean Treated Steels.
#21364 Mechanical diode kit $229.00
This kit comes with everything necessary to convert over to the updated mechanical diode one way clutch. The factory one way clutch was prone to failure even in stock applications.
#22500 Direct Input Shaft $149.00
This shaft has become a problem when increasing the power. It has been known to break on a wide open 2-3 shift. Our shaft is made of superior 300M material.
I found an Art Carr-Recommended shop that will drop my original tranny, install the above, reinstall it, and test it, for $425..Will only need to leave it there for 2 days.
RC
