306 Long Rod? Whats the deal?
155dB5.0
165
Upper MI
Just wanting to know whats so good about a 306 Long Rod? What benifites does it have and dose it make more power than a normal 306? Also can you get a long rod in any other size?
Thanks Darren
It makes more power only because you can rev the piss out of it.....7500-8000 compared to 6000-6500. because of the 1.8 rod ratio, so you pistons speed is lower per given rpm, so you can run a big big cam...... but sucks for daily driving
from what I've heard, the long rod means that you can use a shorter piston which is more stable because the wristpin is closer to the top of the piston. I don't think that the long rod makes more horsepower so much as it has more potential. i dunno though
you missunderstood, i ment it would suck driveing with a big cam on the street. haveing a big cam with a long rod motor becasue thats the hole point (addvantage)of running one to crank out more rpms/or longer stastined rpms. its pistons G's that decress with a long rod motor
A longer rod makes the angularity of the rod less, making it easier on pistons and give a better ring seal. A long rod also increases the dwell at the TDC and BDC for better scavenging and INCREASES the piston speed in between to make up for that. The shorter pistons are also lighter, helping the motor rev easier.
155dB5.0 said:
So would this not be very ideal for my aplication?
And are there cams that i could still spin high RPMS but have a good streetable cam?
Darren
Depends on what you consider streetable. A high RPM cam will not idle very well, and requires you to cruise, and shift at a much higher rpm than you are used to. I think of these things as being awsome :nice: , but some people don't like these traits, and want there car to drive like stock, wich it won't.
I dont know exactly HOW it works, but variable valve timing would give the best of both worlds. However I don't know if it would be in any way possible on a non modular engine because of the placement of the cam and whatnot... hmm, anybody know if that would be possible?
I agree with Matty50. A long rod 306 would have better rod ratio, which puts less force on the cylinder walls and directs it more on the crank. That is part of the debate bewteen the 331 vs. 347 debate. The long rod would use shorter pistons with a higher wrist pin. I don't know if the hp:$$ ration would make it worth it. I don't really know enough about the LR 302 to tell you anything.
