hope someone can help. Dropped in a new 306 .upon start up the oil filter cracked at the base. Thought maybe bad filter. Replace it .started again and drove it home ,no issues. Took it out for a drive and rear main seal blew, ok maybe dry rot from sitting before i bought it. Replaced that ,drove it home no leaks. Took it out again and back of head gasket is leaking oil onto top of motor! And I found the pvc valve out of intake. Thinking too much crank pressure but I haven't put anything in the valve cover grommets yet. Don't want to replace head gaskets and have something else leak any ideas? Thanks
and if you're stealthy the cook will never notice.
