- Sep 16, 2006
- 4
- 0
- 0
Hey folks, I posted here a few times in the past looking for a Stang, but I finally found a clean 89 LX. Thanks for all the help in doing so. My dilema is that I will be bringing it to Laroccas' for a full tune and dyno within the next month and I am looking for some input. The motor is now a 306 with forged pistons, milled crank, Track Heat intake (upper and lower), Trick Flow Twisted heads with 1:6 rockers, F-cam, Edelbrock 70 mm throttle body, 4:10's in the rear, a AOD with PA components and a TCI Street Fighter converter with 3000 stall. The complete tune will be around 675.00 with a chip burned, this includes the dyno. My concern however is whether or not this set up will work in harmony. If any changes need to be made to make this combo work better, I need to do it before the tune and chip or else I will need to blow another 675.00 for changes made after the tune. Is any one out there running a similar set up? I purchased this car with this set up, all except the TCI converter. Any guesses on the dyno numbers? I believe the headers are BBK, no cats with a H-pipe. Thanks in advance. Thirsty. Forgot to mention 24lb injectors.
