331 Scat 4340 forged steel rotating assembly, plus a whole lot more
304billet
315
have 331 rotating assembly set up for boost - Scat 4340 forged, knife-edged, double keyway crank, Probe lightweight forged 4340 I beam rods w 7/16" ARP cap screws and Probe forged 2618 dish pistons -14.22cc, Probe tool steel wrist pins, all balanced @ 28oz - $1,700 plus the ride, rotating assembly good to 1000-1200fwhp. has 1000 street miles. liteweight RA spins up real fast.
plus a whole lot more for a boosted 331 stroker - canton 7 qt pan, windage tray, Probe main girdle w/ ARP main studs, Romac ultralite damper, Fidenza aluminum flywheel, Isky chrommoly pushrods, all ARP head studs and ARP throughout, Cam Motion custom grind cam -.560/.576 lift, 229/239 dur., 114LC, Melling SP/SV oil pump, Probe billet steel oil pump driveshaft, FRPP double roller timing chain 9 way adjustable, FRPP HR lifters, 302 stock roller block, bored, magnafluxed and clearanced for stroker. all above have 1000 steet miles.
TFS Twisted Wedge Track Heat 205cc cnc’d race heads, 72cc, 7/16” stud mount, flow 300/220cfm @ .500 lift, 316/231cfm @ .600 lift, 1000 miles, street time only. $1700 shipped
Harland Sharp 1.6 roller rockers, specially designed by Fox Lake Racing and HS with an offset intake rocker for better geometry, 1000 miles, $250 plus the ride
TFS-R intake full race port by FPS, flows 325cfm, 1000 miles - $700 plus the ride
e-mail: [email protected] --------------pics available later this week
will make a package deal for this race engine, pan to intake. located near Los Angeles, CA
