331 stroker and...
  • Thread starter Thread starter lincoln+ford
  • Start date Start date Sep 28, 2009
  • 3
1 of 3 Next Last
lincoln+ford
195
  • Sep 28, 2009
331 stroker afr 185cc compression ratio staic should be 10.5.1 going to run N-71 cam and parker funnel web intake.What do you think ill make for hp?Im guessing im better off with the N-71 over the triclflow stage 2 cam?As in make most hp wise.
89stang1
Stroked and Juiced
730
234
74
nj
Sep 29, 2009
  • Sep 29, 2009
I have a 333ci at 10.7:1 with AFR 185s, cobra intake and a comp nitrous custom grind cam, my car made 360RWHP and 383RWT on a mustang dyno
lincoln+ford
195
  • Sep 29, 2009
So my parker funnel web intake and n-71 cam i should beable to hit 400rwhp on a dynojet lol.
Are you still factory block?How much spray do you plan to hit it with?
89stang1
Stroked and Juiced
730
234
74
nj
Sep 29, 2009
  • Sep 29, 2009
LOL u never know ive seen 347s with bigger heads and higher lift cams than mine put down only 300RWHP on a dynojet..........im sure u have too, no guarantees alot depends on who builds it and matching the right mods together. Seems like u put together a nice choice of mods should make impressive power, only thing i would change out would be for a custom cam just a couple more bucks easy for me to say im still using a factory block thats why im taking my time with NOS..... tough spot where im at hp wise cause if i came out around 300RWHP on the dyno i would hit it with a shot for sure, but my smallest shot in my kit is a 75hp shot gettin up there...........i plan on doing it anyway in the near future its all hooked up just need to get back on the dyno and have a nitrous program (less timing) on my 4 bank chip
EMW150
2,020
Roaring Spring,PA
Sep 29, 2009
  • Sep 29, 2009
Don't underestimate the Anderson Cams. They work really well. See sig. My old combo with the N-111 in my '84 made 433 to the wheels. I just pulled that engine and stuck in my '87 LX with a set of out of the box 192 Canfields , Anderson N-71 cam, Vic Jr, and 750 Holley. I'm guessing it around 400 to the wheels. I don't have any experience with the Parker Funnel Web intake though.
lincoln+ford
195
  • Sep 29, 2009
Yeah ive seen on streetfire.net a guy running a 331 efi and he was running a 175shot but hes got alot of videos of racing beating the hell out of the car with a stock block.It just pisses me off sometimes that ford had to make the stock block so weak.
Yeah im almost thinking about going custom cam i mean the N-71 is 300bux alone and i know must customs cams cost almost that.
lincoln+ford
195
  • Sep 29, 2009
You should pm me your suspension set up that launch was nice as hell to bad about it being stuck in gear.Or post it on here which ever thing looks like it really hooks.
EMW150
2,020
Roaring Spring,PA
Sep 29, 2009
  • Sep 29, 2009
UPR Anti-roll bar, QA-1 rear coilovers, UPR LCAs, Baseline suspension uppers, and UPR coil overs in front with crappy old 90/10 Lakewood struts. That was a 1.450 60'. Wish I could have ran out that pass. Haven't got to run the car since.
89stang1
Stroked and Juiced
730
234
74
nj
Sep 29, 2009
  • Sep 29, 2009
No doubt Anderson cams are one of the best off the shelf!!, just hard to beat the way a custom grind can meet all the needs of a engine
lincoln+ford
195
#10
  • Sep 29, 2009
  • #10
Any idea of the weight of the car?Mine is a 89 lx going to get a tubular k member and a fiber stock hood.wanna try to get it to weigh atleast 3k with me in it.What gears where you running?
D
defcondaze
48
#11
  • Sep 29, 2009
  • #11
i have the n-61 in my 331. compression is around 9-9.5:1 TW heads
about 350 RWHP on mustang dyno
EMW150
2,020
Roaring Spring,PA
Sep 30, 2009
#12
  • Sep 30, 2009
  • #12
It's around 3100 lbs, full interior, steel roll cage. It has the QA-1 tubular K with QA-1 control arms and a Cervini hood which is one of the heavier ones. Gears are 4:56s.
lincoln+ford
195
#13
  • Sep 30, 2009
  • #13
Ahhh those gears lol i know im gonna go to 4:10's at the very least im kind of thinking 4:30's so if for some reason i have to cruise at 65 ill throw on a tall tire maybe some 31's lol jk.
EMW150
2,020
Roaring Spring,PA
Sep 30, 2009
#14
  • Sep 30, 2009
  • #14
LOL, yeah, keep in mind though that was with the N-111 cam not the N-71. I was shifting the thing at 7,800. I have 4:10s in the '87 that the engine is in now with the N-71. I think it would probably like 4:30s a little better though.
lincoln+ford
195
#15
  • Sep 30, 2009
  • #15
damn 7,800 lol .Id need different heads to support that high rpm.But yeah i prolly will just go 4:30's i dont plan on driving it to the track but would be nice to cruise some spots around town with it.So basicly my set up and 100shot im on borrowed time?Would using block filler and only filling half way to the bottum of the water pump holes do any good?My colling system is up to par and im thinking about running on e85 as theres a e85 gas station like 1 block away from me thats open 24/7.So i think if i do fill the block and e85 would be a nice set up as you run cooler on e85 and with block filler thats a plus.
EMW150
2,020
Roaring Spring,PA
Oct 1, 2009
#16
  • Oct 1, 2009
  • #16
E85, isn't that ethanol?
lincoln+ford
195
#17
  • Oct 1, 2009
  • #17
Yes well 85% is ethanol and 15% is gasoline.Scratch that for got i had to get a carb or conversion carb kit.Id rather just run some 93 and keep a few gallons of race gas at home for when i spray it.
304billet
315
#18
  • Oct 3, 2009
  • #18
How r u getting the hydraulic roller lifters to spin to 7800 w/o floating? almost all sign off at 6500? R u using Sherman racing hydraulic lifters that r modified Morel lifters that act like a solid lifter after 6000rpm?
lincoln+ford
195
#19
  • Oct 3, 2009
  • #19
I forgot where i seen it on but there was a company site anderson or someone that spun a motor to 7400 with stock ford racing lifters and they held up.
EMW150
2,020
Roaring Spring,PA
Oct 4, 2009
#20
  • Oct 4, 2009
  • #20
Stock Ford Lifters about 6 years old. It's all in the cam design. It does require new valve springs every year.
  • 3
1 of 3 Next Last
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
Engine LOSS OF POWER AT 4,000 RPM.
  • Jarhead67
  • Nov 17, 2024
3K
Fox 5.0 Mustang Tech Jan 25, 2025
Jarhead67
J
Engine An engine building combo with stock Speed Density (SD) system
  • Mcmahst
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 15, 2025
Mcmahst
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
