Im looking for 331 short blocks.... This will be going into my 93 gt, and will be a daily driver. Im probably going to use either trick flow or holley heads, trick flow intake and stage one cam. I've be checking out the dss and chp blocks....but i came across another place that builds motors. They have a 331 for 1500 bucks. I couldnt believe the price, seems too good to be true. Here what it has: 5140 forged i-beam connecting rods with full floating pins, forged pistons(not sure what kind) w/11 cc flat for 9:5:1 with 60cc heads, digital balanced rotating assembly- 28.8 oz balance, clevite rod and main bearings, hand fit moly pistons rings, bearing clearances checked and noted, durabond cam bearings installed. It seems like a good deal. The other short blocks i was looking at are closer to 2k or over. what do you guys think of the short block i just listed? Better to spend the extra cash to get better internals? Also, i need some help on what i should be looking at. Like the difference between 5140 forged i beam vs. 4140 or 4340? Should i go h beam or i beam? What about the balance, 28 oz or 50 oz? I plan on maybe adding a blower later on, for now will prob be n/a. The other short blocks i was looking at came with 4140 forged i beams, basically very similar and are about 2100. As mentioned before, this is my daily driver, looking for between 350-400hp but still need to pass smog, etc. I know i need to go with forged pistons but what about the crank? Any opinions/help would be greatly appreciated! Also, anyone know how the lope is for the trick flow stage one cam? Thanks
