Funny this came up. I was on the phone with FRPP asking about old blocks last week, and the topic of the Boss 302 block came up. FRPP openly admits that the bores are shorter. You can actually stroke it all the way up to a 3.500" stroke with no problem. The only hurtle comes from piston selection. You have to use a piston specifically designed for that block, and they are available. People are having trouble making stroker engines with these blocks because they are using traditionally available stroker kits. Ford made the block with shorter bores specifically so that you could run a 3.500" crank on it. The obvious point is that it is cheaper to use a traditional stroker kit with a Man O War block, or a Dart block (which are the same or cheaper than the Boss 302 block), then to hunt all over the performance market looking for those specific pistons with the dish you want for a blower. I don't see why you won't be able to make 1100 hp on a 347 with a blower, but I won't say that it will be street friendly. If you want a street friendly 1100hp, I would consider a turbo setup. If you have your heart set on a new Boss 302 block, all you have to do is call FRPP, and they will set you up with the correct pistons that you need. It's really not that big of a deal.
Kurt
