347 Help
  • Thread starter Thread starter NewStangOwnr
  • Start date Start date Jan 3, 2008
N
NewStangOwnr
152
  • Jan 3, 2008
I'm in the process of buiding a 347, and am on a kinda limited budget.
Over the summer I plan on adding boost, so I would like do build it right, now instead of later.
So forged crank,rods,pistons,etc. Any on kits people have used? I plan on going with a 5.315 rod instead of the 5.4 for the oil ring problem.
I have enough to cover the stroker and machine work, and maybe 9-1g after that.
I would like to do a roller cam maybe? Rocker arms? Or should I leave everything and just get AFR 185s?
Thanks for the help, I cannot decide.
65fastbackresto
1,229
AR
Jan 3, 2008
  • Jan 3, 2008
I almost went a 347
Could have afforded it too, but I`m glad I didnt. My builder did a mild build on a 302,10 to 1 compresion with edelbrock heads and intake, and this thing will scream. Unless your planning on racing I`d stay with the 302, it`ll surprise you if you build it just a little I bet.
65fastbackresto
1,229
AR
Jan 3, 2008
  • Jan 3, 2008
I almost went a 347
Anyway I looked at some Eagle rotating assemblys, check em out, heard good things mostly about them.
coolblue65
1,224
Algonquin, IL
Jan 3, 2008
  • Jan 3, 2008
I love my 347!!!!!!!! it was a night and day difference from my built 289 that I took out.
Anyways, the first thing is, what is your budget? And why do you want to boost it? only reason I ask is that you can and will make tons of power from a well built 347 without boost.
I ended up using a DSS (forged pistons and rods & balanced) shortblock w/AFR 185s (you can see the details in my Cardomain page) keep a look out out on some of the forums and you can probably find a good deal on new parts from someone who changed their mind.
Hack
1,945
Minneapolis
Jan 3, 2008
  • Jan 3, 2008
Well, this isn't the advice you're asking for, but a strong 347 with boost means your block will probably not last very long. It would be a huge waste of money to build this thing and have it blow up in short order.
I don't see what year your classic is, but a 351W is a lot stronger block to handle more power. It will fit in the older Mustangs. For about the same money as your 347 you could have a 408 and a much stronger base for performance.
What are your goals? If you are all about straight line performance you'll get a cheaper, more reliable end product with a big block. If you really want a boosted 8.2" deck block, I'm thinking you should look at Dart or World (or the new Boss block at a minimum).
N
NewStangOwnr
152
  • Jan 3, 2008
I plan on boost for over the summer, and I already have a Dart 302 bolt, 4 bolt mains,etc. I'm saving it for the summer, I just want the 347 because I spun a rod bearing and would rather get the stuff now instead of later.
How much power are you making coolblue?
coolblue65
1,224
Algonquin, IL
Jan 3, 2008
  • Jan 3, 2008
Unfortunately I haven't been able to get the car to a dyno yet, but I am sure its somewhere around 430-440HP at the flywheel. There are several other members of the forum who have almost the exact same combo as mine and are running low 11's in the 1/4 with slicks. I only made it to the track once with the new motor, and my best on small street tires is a 13.2@109.
If the salt clears up here I might try to get it dynoed before spring.
N
NewStangOwnr
152
  • Jan 3, 2008
Cool. I was talking to a local shop and they said that some 347s that they've seen have been around 4xx at the wheels. But any advice on what to do?
T
theautomatics
37
Chicago
Jan 4, 2008
  • Jan 4, 2008
Hey coolblue65, I'm over in Norridge. I've got a blue 67 mustang coupe with a 331. Maybe I'll see you at the grove eh?!
Why not go with a 331 stroker and use boost? You still have enough wall strength with a 331 for that kind of compression. I've got a 331 with afr 185's right now and I'm going to set it up for boost this spring.
jcode68
892
Massachussetts
Jan 4, 2008
#10
  • Jan 4, 2008
  • #10
I swapped in a 347 with AFR 185's and the car is scary fast, couldn't imagine adding boost for the street. If your goal is racing, then you probably want to take a different direction as others have pointed out. I haven't dynoed my car yet, but CHP claims 405 hp, 420 ftlbs at the flywheel with my combo. Compared to my stock 302 that I replaced, it is a true night & day difference.
Hack
1,945
Minneapolis
Jan 4, 2008
#11
  • Jan 4, 2008
  • #11
I believe that. I haven't had my '83 dynoed, but it probably makes less than 300 hp with 9.1 compression, a '93 Cobra top end and a Comp cams XE270HR-12. It makes me nervous when I'm pushing it hard. I think with 400 or more hp I would be afraid to use that power much on the street, and my car might not even be drivable 3 or 4 months out of the year.
G
gp001
4,401
So. Cal.
Jan 5, 2008
#12
  • Jan 5, 2008
  • #12
my 347 made 338 rwhp with a wimpy cam and shutting down early on the dyno. 400 rwhp would be easy with a decent cam.
Shakin66
628
Waycross, Ga / Lake James, NC
Jan 5, 2008
#13
  • Jan 5, 2008
  • #13
As an owner of a supercharged 347 I would have to say go for it. My car is docile enough for my wife to drive to the grocery store or if you want 400 plus HP its there. I have a 9# used powerdyne for $800.00 and while there are "better" s/c out there it has worked out great so far. I am also using Dart's pro one heads and have been really pleased there also. PM me if you want some pics or tech on my combo. I will latter be going F/I but I am having to much fun with this blow thru carb. Just be ready to spend some time thinking about your fuel system...
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
R
351w stroked to 408 CARB
  • Ric4eyedFox
  • Mar 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2025
General karthief
Motor given to me and I’d like to rebuild it what do I need to do
  • Creomod
  • Dec 14, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 16, 2024
AeroCoupe
J
Holly High ram setup on 347ci SBF NEED HELP
  • Jschallitz
  • Jun 7, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 7, 2024
