So, after putting a 347 in my ranger, I ran into some issues. turns out the setup I had, would not advance the timing. (Ran a 14.2 with a 302 with no timing advance!!) I'd used a 95 mustang FEAD, and distributor, and 89 mustang PCM...didn't work.
So, I bought a 95 mustang. took the entire PCM, and wiring out of it, and fitted it to the ranger....
Now, it has issues. Serious bog issues, will not make power at WOT, idle is poor, but seems like there is a "sweet spot" if you find it, the truck (car) makes serious power...
basically, this is now a 347 in a 95 mustang GT.
I'm using the Auto computer, with a manual trans. will this cause issues?
What else would cause this? the TPS checks out. (.899, up to .499 at WOT) Fuel pressure at 42psi.
Balanced 347, AFR 185, XFI stroker cam, 1.6 rocker, 24# injectors, with 24 Granatelli MAF.
Trick flow intakes, 1-5/8 headers, 70mm TB and spacer.
Is there data-logging available for these, to see what the PCM is seeing, and doing?
Summer is almost over, and I'm at wit's end, almost to the point of giving up on her, and tossing in the BBK Instacharged 4.0L that's nearby......
Suggestions VERY welcome.
