- Aug 7, 2008
- 97
- 0
- 6
I have been trying to decide what would be a better motor choice for my 95 GT. The current engine is in fine running condition and does not need a rebuild currently, so this whole process is to get a determination on what to do in the future.
I have a good doner 351W roller engine that is running happily in 95’ Ford F150, but was purchased solely for this future purpose. The problem is, the cost factor of getting the 351 w into the car may overshadow the benefit?
The 351 w will require different headers, intake, most likely hood to look after clearance issues, but will benefit from a beefier block with capabilities of going up to a 427 cu in if ever desired.
Now a 347 will achieve 400+hp power levels, be torquey and fun to drive but there is concerns with durability and reliability of the stock bottom end and stock engine block handling that power rating as it is reaching the limits of the factory castings.
I realize that a lot of the extra cost of putting the 351w roller into the car would be similar to what it would cost to get a 347 in the car since the currenty heads, cam, intake on the 302 in the car would not serve well on a 347 or a 351/351 stroker configuration, so that point may be moot.
The upside to the 351 is that it has a stout enough stock crank for most street applications (and this is the primary useage) and the block is also strong enough to eclipse 450 HP ratings.
I’m looking for comments from both parties to determine what they encountered in regards to cost of building/installing either engine.
HCI – both engines will require a larger cam, head, intake setup. Heads may interchange, but may not be sufficient for a big bore unless your heads were way oversized to begin with on the 302. I’m told my Thumper ported GT 40 with larger valves still won’t flow enough for a 347 or 351, let alone a larger cu in stroker.
Intake is not interchangeable with the 351 as the 302 is not wide enough. With a 347, I may get away with my ported lower and a cobra upper which could save a few bucks?
Hood will be an unavoidable cost since there isn’t too many EFI setups on a 351 that will fit under the stock sn95 hood. A GT 40 5.8 intake may help, but for what they are worth on the used market, not financially feasible, so you WILL need a hood. How large will be determined by what intake you end up with??
Headers – long tubes are available for the swap, but very expensive. 347 headers are abundant and easily accessible and cheap. Long tubes shouldn’t be as difficult to acquire or install either.
Both will need a chip to tune and most likely larger injectors than my current 24lb ers. Stock 70 mm MAF and 65mm throttlebody should work fine??
Flywheels and balancers are also not interchangeable so money will need to be spend there as well, whereas a 347 would not need it.
I guess it boils down to useage, desireable power level, and practicality. Obviously the 347 will be the easiest to install since it is basically a punched 302. The 351 will have issues and tribulations, but can fit…but is there any use putting in a 351 if a 347 will have very similar power/torque numbers? If your going through all the trouble of installing a 351, it may as well be a 393 or 408…….but then you have pretty much defeated the purpose of daily driven/street car??
Any thoughts/ideas are welcomed…
