347ci Crank and Pistons
VicRattlehead
519
ChiTown Il
Ross Racing pistons
there are 8 pistons here however 1 has a crack in the dome, and one has some pitting in the dome. the other 6 are good and reusable.
Ross Pistons:
4.030 bore
.004 clearance
1.085 compression height
12:1 w/ 64cc head
20* head
build number for these pistons is 60554 youll need this number to order replacement pistons.
Rings are included for all 8 pistons.
Total Seal Rings - .043 .043 3mm
4340 forged steel crank
Crank stamped as 302 3400 5400
302 block
stroke 3.400
rod length 5.400
Standard standard grind
Crank is 28oz External balance
$350 for pistons and rings
[email protected]
815-254-2333
parts in Plainfield IL 60585
pistons..
2 bad pistons.
first has 2 cracks.
second has some nicks in the top
