629RWHP Procharged Mustang 90 GT
629RWHPstang
NY
Procharged R347 90 GT
Car was tuned by jimmy laracca and put down 629RWHP and 599RWTQ with a 14lbs pulley on 93 pump gas.. i really never drove it since i got it back about 6 years ago.. basically ran out of money but ha plans to do a T56 and build the rear...motor has about 6,000 street miles AT MOST.. about 130,000 on the body... very reliable street monster and the only mechanical issue is the fan took a dump and the car will climb to 200f at idle.. but while driving it stays at 185 as it should..
Have over 6k in the bottom end alone guys im asking 9k OBO
motor was Built by D&D motorsports..
Pro hawk 347 Competition short block
-Ford racing 302 R race block
-custom ground hydraulic roller camshaft
-AMP small block ford timing set
-ARP ford cam bolt
-28OZ small block ford SFI balencer
-302 siamese bore wet sump block
-8.200 Deck hight
-CAT 4340 Forged steel 3.400 stroke
-2.2486' Main,2.1232'rod
-4340 Forged steel H beam rod,5.400 length
-.927 Pin,610 Grams
-ross custom forged pistons
-akerly & Childs xtream moly rings
-clevite 302 Rod H bearing
-Clevite 302 main H bearing
-Mccleod aluminum SFI flywheel-28 OZ
-Brodix Track 1 heads-2.08/1.60 68cc,194 intake
-full aeromotive fuel system lines/sump tank---Weldon fuel pump D2025-A
-Brand new(230 miles) mcleod twin disc clutch kit
-General Systems Research stand alone, wire harness
-Innovate Air/Fuel gauge
-Hooker Headers 6227-1HKR
-Custom Dr Gas 3 inch X pipe
-magnaflow Dumps--sickly sexy sounding
-CSI electronic water pump
-fluidyne radiator
-black magic fan
-CSI overflow tank
-Ford Racing Super-Duty T-5 Transmission--(3,000 miles on it)
-moroso 7qt race pan
-D-1SC PROCHARGER-3 CORE INTERCOOLED SYSTEM
-BBK 75MM throttle body
-Energy polyurethane motor/trans mounts
-Trick Flow 7/16,1.72 Rockers
-custom chrome valve covers with morosso welded breather kit
-csi thermostat housing
-Weld Draglights all around
-REAR END IS STOCK OTHER THEN 373 GEARS AND AXLES!! new in box) 31T Auburn Posi,Ford 8.8 -200AMP 3G Ford Alternator conversion
-MSD 6al Box
-MSD blaster coil
-Melling high volume oil pump
-B&M Ripper shifter
-EDELBROCK PERFORMER RPM II intake manifold
-tokico 3 way adjustable shocks.. from the inside of the car
-line lock system
-autometer boost gauge
-autometer temp gauge
-atometer shift light [hidden]
-MT street radial(100 miles##
-optimum batt, relocated to trunk
-subframe connectors
-Air dam
-maximum motorsports lower control arms
-adjustable clutch Quadrant
-torque arm(forget what brand)
-powerstop crossed slotted rotors
Feel free to PM me ith any questions guys or call/text me at 845-826-2326 thanks!
pics are to big so i can email them to you if you like
Procharged 347 Mustang - YouTube
