Need some info on the 351 cleveland as opposed to the 351 windsor. any information would help. Which engine is better? Why? etc. thank you
302RWP said:Need some info on the 351 cleveland as opposed to the 351 windsor. any information would help. Which engine is better? Why? etc. thank you
brianj5600 said:How much do these heads cost ready to run? They are 30+ years old. By the time you buy them, new valves, springs etc. you have 30+ year old, old tech, heavy cast iron heads. They will make great power, I know that, but the valve size and port size are on the big size for a broad power band. I'm sure you know about the exhaust ports short comings as well. For me, I like aluminum heads designed in the last few years. Cleveland heads can get it done, but if it isn't all out racing, I'll stay with the w's
I put out 400 (394) RWHP through an AOD and 9 inch rear (assuming 20% parasidic loss thats 500 HP at the Flywheel) all with a very mild lope at 10.5:1 compression with the only mod to the heads being screw in studs for my rollers and mild porting on the exhasut side. So it is one extremely streetable racer. Conversely if you stroke out a 351w you have to buy aftermarket heads to get the same level of performance.dodgestang said:Its amazing what happens to 351c heads when you stroke the bottom end to say 408 cubesI put out 400 (394) RWHP through an AOD and 9 inch rear (assuming 20% parasidic loss thats 500 HP at the Flywheel) all with a very mild lope at 10.5:1 compression with the only mod to the heads being screw in studs for my rollers and mild porting on the exhasut side. So it is one extremely streetable racer. Conversely if you stroke out a 351w you have to buy aftermarket heads to get the same level of performance.
I have always been a big fan of both motors and have run both motors in mustangs. Price wise I always say to build what you have. If you have the 351c it will be cheaper to build it and get 400-450 HP out of it than it would be to by a 351w and then build than one. Similarly if you have a 351w it will be cheaper to build it and get 400-450 HP out of it than it would be to buy and build a 351c. The 351w are more plentiful and for the most a small percentage cheaper than comparable 351c parts......but then everything you save you have so spend on new heads
Sure there is a weight savings, there is no arguement there, but in all honesty if you are building a car to see the weigh savings from Iron heads to Aluminum heads on a time slip.....you got deep pockets...and then you can buy the aftermarekt 351c aluminum heads from places like CHI.
SadbutTrue said:We had a 351c ready to install but with a test fit it wasn't going in, not easily anyway. For 67-70 this isn't an issue, but there is some debate as to whether a 351c will work in a 65-66 bay.
67GTA-FB429 said:Nick; what is the red and black arm that is extending back from the shock tower to the firewall?
do you like the K&N filter? what size is that?
fastcoupe68 said:Just wanted to clarify something some one in this thread said that a stock 351w block couldnt handle more than 500hp. You are sadly mistaken. I have personnally run built and purchased in crate motor form 351w that make substantially more than 500hp and never had a block failure, as a matter of fact I know of one that made 870hp with forced induction that was run at the track quite often for three years with just preventative maintanance and never had a problem.
