I know there was a sticky a long time ago, but it seems to have disappeared. Right now, I have the opportunity to buy this 351 from a friend of mine who is in need of cash. He built this for his late 90's Fox. He got a 351 from a 96 Van pulled it apart, saw everything looked good, put it back together. He says right now as it sits, it should be at 9:1 compression. He wants 1600.00 for this and it is sitting on an engine stand ready to be sold. Everything on here is made for the swap. The only thing I will need is a new belt, a steering shaft and that's pretty much it. Can you guys go over this list and tell me what you think? I know I will need a hood for sure. But that's the least of my worries.
The 351 has a fair amount of stuff done to it... and it is a 1996 roller cam motor with 81,XXX miles on it.
Ford Racing 57 tooth 28.2oz imbalance fly wheel
Ford Racing windage tray
Foird Racing oil pump and oil pump push rod
351 swap pan
1985 351 heads with port work and 1.94 intake and 1.60 exhaust valve. They are decked to only have 67cc chambers versus 69cc's which is stock. Comp Cams valve springs.
GT-40 Marine lower intake
Explorer upper intake
Factory 5.0 HO camshaft
Ford Racing 30# injectors
75mm Professional Products throttly body
70mm BBK spacer (I had plans of port matching these...but I'm not going to)
Mr.Gasket crankcase drag outs
Ford Racing A/C bracket (yes this motor is intended to run all accessories)
New Alternator
New power steering pump
New water pump
New ASP aluminum under drive pulleys
Freshened A/C pump
All sensors are NEW
Long tube swap headers
H-Pipe for long tube headers
Good condition King Cobra clutch set
All gaskets and seals are new...and high end (I wont install cheap gaskets and seals)
1995 Starter (lightweight gear reduction)
All NEW hoses
NEW black magic fan
BBK fenderwell cold air intake
C&L 87mm MAF calibrated for 30# injectors
NEW orbital battery
NEW MSD plug wires
NEW MSD coil
NEW MSD Dis-6 ignition
ARP fasteners throughout most of the motor
2003 Cobra mufflers (to keep things quiet)
Moroso solid motor mounts
Ford Racing 160 MPH speedo
Kirban adjustable fuel pressure regulator
Brand new battery cables
New Bosch Platinum plugs (I run them in all my toys)
New Starter Solenoid
351 swap pan
New Alternator
New water pump
Freshened A/C pump
All sensors are NEW
All NEW hoses
NEW black magic fan
NEW orbital battery
NEW MSD plug wires
NEW MSD coil
