351 heads
5.0_sleeper
47
Hey, got another question for you guys. I was wondering if 351 heads would fit on 302 and be able to use the stock 302 intake manifold? Also was wanting to know if the 351 heads would be big enough for fms f cam, as far as piston to valve clearance or not? Or if I go with 351 heads will I have to get 351 intake manifold to fit.
thanks
5.0_sleeper
Late model 302 and 351 heads are the same.. only ones worth the swap are 70's...the later ones have bigger chambers, you'll loose more HP with the loss of compression then you will gain from the bigger ports. If they need going through.. valve job, springs etc.. it usually isnt worth it, aftermarket iron heads would be cheaper.
