351 motor
  • Thread starter Thread starter phantomxdino
  • Start date Start date Mar 21, 2010
P
phantomxdino
25
  • Mar 21, 2010
I got a 88 gt with a stock 302 in it, i broke the end of the crank so now for a quick fix im going to throw a 351 motor i got in it. the 351 is carburated and i had a few questions on the swap. Can you use the same throttle linkage. Do you need a diffrent bell housing. What kind of change do u have to make for the fuel lines cause i might want to go back to fuel injection. let me know what you guys think thanks.
2000xp8
SN Certified Technician
Aug 8, 2003
8,072
1,656
194
NJ
Mar 21, 2010
  • Mar 21, 2010
That is no quick fix for sure.
A quick fix would be an explorer engine, a used 5.0 or converting the 351 to fuel injection , but changing to a carb and a 351 is more work and probably more money.
LarsD
2,680
119
123
Texas
Mar 21, 2010
  • Mar 21, 2010
This is what I would do if I needed to replace the 5.0 in my 91 and I was trying to do it quick/cheap.
P
phantomxdino
25
  • Mar 21, 2010
To convert the 351 to fuel injection can you use the stock 302 intake or do u have to modify it to compensate for the taller deck on the 351?
2000xp8
Aug 8, 2003
8,072
1,656
194
NJ
Mar 21, 2010
  • Mar 21, 2010
You need a 351 lower intake.
There are several out there made this way, and i believe you could also use the gt40 intake off of an older lightning.
SpartaPerformance
2,517
61
89
Long Island NY
Mar 21, 2010
  • Mar 21, 2010
I agree that is no quick fix!! To fuel injected is rather simple, 351 lower intake, if you get one from a truck I believe you can use stock upper bur don't quote me on that I've done GT-40 intakes back in the day they were still available new and cheap. As for bell housing it's the same, you will need a new flywheel for a 28oz in balance, distributor from a F.I. truck like a Lightning for example, 351 fuel rails, 351 "fox" swap headers and a few other minor doohickeys. Good Luck!!
P
phantomxdino
25
  • Mar 22, 2010
well looks like im gonna try for the explorer motor cause i did some research and sounds like thats the easyist way to go, cause you can just use the intake off that motor and swap out the pan and oil pickup(thats what i read) thanks for all the great info you guys gave me!
2000xp8
Aug 8, 2003
8,072
1,656
194
NJ
Mar 22, 2010
  • Mar 22, 2010
Just remember to budget for gt40p headers, if you get an explorer engine out of one 97 or newer.
P
phantomxdino
25
  • Mar 23, 2010
whats a good site to find a set of those?
Sleeper5.0
11
Quebec
Mar 23, 2010
#10
  • Mar 23, 2010
  • #10
MAC make a set p/n:50158. Mac Performance - performance accessories for cars, trucks, and motorcycles
2000xp8
Aug 8, 2003
8,072
1,656
194
NJ
Mar 23, 2010
#11
  • Mar 23, 2010
  • #11
Buy the ford racing p headers, mac makes garbage (i speak from experience).
LarsD
2,680
119
123
Texas
Mar 24, 2010
#12
  • Mar 24, 2010
  • #12
I had a set of Ford Racing "P" headers on my old 89, those were some of the best fitting headers I've ever had.
BAD STANG
14
#13
  • Mar 24, 2010
  • #13
as far as the fuel lines go if you go carb.summit has a fitting that has a barb on one end for regular fuel line and it snape into your fuel injection line.you will also need a pressure regulator.
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
  • dan50
  • Jul 18, 2026
dan50
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
T
Engine Need help figuring out misfire and backfire
  • trystancounts
  • Sep 25, 2025
Fox 5.0 Mustang Tech Sep 26, 2025
