  • 1994 - 1995 Specific Tech
351 stroker- NA or Power adder?
  • Thread starter Thread starter squall9393
  • Start date Start date Dec 24, 2004
squall9393
534
Oceanside, CA
Dec 24, 2004
  • Dec 24, 2004
What is a better street/strip route to go with a 351W stroker? NA or power adder? Not concerned with money or gas milage. It will only be a weekend cruiser or occational track participant. I wanna know if I can get the same power numbers from NA that I can from having boost but it being cheaper since I didn't have to run forced induction.
Joes95GT
3,132
Delaware
Dec 24, 2004
  • Dec 24, 2004
If the car needs to have reliability, you aren't going to see the power you would see if you used a supercharger. Sure you could have 700 RWHP N/A out of a 408 or something, but driveability would be sacrificed.
Joe
Gt1995
127
Tampa
Dec 24, 2004
  • Dec 24, 2004
how many cubes were u goin for ?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 24, 2004
  • Dec 24, 2004
351w
i have a 351 w in my stang. im going with a N/A stroked motor. hard to decide which 1 though because a 393 needs no connecting rod clearence notching which means i would probably attempt the build myself however a 408 short block is prettry tempting. with afr heads N/A 408 can make easy 525hp. sound like enough street power to me well for a year or 2 till u get used to it. i run juice on my 351 now and i love the stuff. special with the digital 6 ignition box with timing retard controls. takes the detonation worry away.
squall9393
534
Oceanside, CA
Dec 24, 2004
  • Dec 24, 2004
I figure between 393 and 427. I just can't deside which one because of compression needed to be answered as well. I don't know what I freakin want yet and it's killing me. I figure if I got whic Joe's statement that boost will keep it clean on the street then a low compression with the most cubes would be best. Can you spray something that has boost or is that overkill? I want to get this issued settled so I can deside what rotating assembly to go with and also what bore and stroke. Would I need a race block to run boost and then add spray later? Do I really need something as strong as billet steel for any possibilities that I may deside to do? I mean can I ever do anything that would require that strong of a crank? How much power is the aluminum crank good for? These are all things I need to deside on before spending one dime.
DougNuts
2,596
Georgetown Ky
Dec 24, 2004
  • Dec 24, 2004
I've been debating this a lot lately. I'll probably end up with a 9:1 compression 393 so I can put an S-trim on it if I feel the need.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
J
Fox body - godzilla, coyote, or 408w stroker - Best route for budget build?
  • jaygee15
  • Jan 27, 2025
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2025
2000xp8
G
Drivetrain trickflow Stage 3 camshaft 347 stroker. also too much gear????
  • Gross Virgin
  • May 2, 2024
Fox 5.0 Mustang Tech May 2, 2024
Gross Virgin
G
Fox Split Block Register
  • FastDriver
  • Jun 23, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2026
AeroCoupe
