351 swap help
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Sep 19, 2008
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 19, 2008
  • Sep 19, 2008
I'm gearing up to put my 351 in my 93 this winter. can i use all the acc off the front of the 302 on my 351? if not i was thinging of makeing my own brackets. also whats the main reason 302 headers wont work on a 351 in a fox?peace
john
393 notch
46
  • Sep 19, 2008
You can not use the 302 ac bracket on the 351. it will not work. you need a 351 bracket from junk yard or summit. the 302 headers wont work on a 351 because of the deck height difference between the two motors. they will bolt up but your h pipe will not reach them. the swap is a piece of cake...
85ragtop
BTW, I like dudes.
475
123
NC
Sep 19, 2008
  • Sep 19, 2008
351w help falls under 5.0 tech since the are almost the same.
Thread moved.
vristang
4,933
101
124
Seattle
Sep 19, 2008
  • Sep 19, 2008
John,
What part of Washington are you in? Interested in meeting up?
Here is some info on the bracket you will need to run the 5.0 accessories...
VRIstang
AC/PS-
This is the only stock 5.0 accessory bracket that requires modification. The original AC pump and Power Steering pump can be reused if an FRPP bracket is used. If using Power Steering only (without A/C), the FRPP part number is M-8511-A351. For both AC and PS applications the FRPP number is M-8511-B351.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 19, 2008
  • Sep 19, 2008
vristang said:
John,
VRIstang
i'm in vancouver wa. i'm not using A/C do you know if you can cap off the power steering lines at the rack so it's manual? will it work or f up the rack? peace
john
DOFOXHC
10
Lebanon, OR.
Sep 20, 2008
  • Sep 20, 2008
john
John, you can do that but it will be a bear to turn....unless you have gorrilla arms! Power and manual racks arent even close to the same as far as trying to turn them with out power. I wouldnt guess its not good on the rack either.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 20, 2008
  • Sep 20, 2008
well most peoples kids have bigger arms then me .........so yeah no grilla arms here. Ok i'll do more research on the rack dealio.as far as tge headers not going to the mid pipe no big deal i'm a welder fabricator so i'll try my 302 mac L/T's then if needed i'll splice in some pipe to my pro chamber then weld it up. I did find some MAC l/t swap 351 headers but if i can make it work and something like that isnt a big deal. Unlike the stupid adapter they make to put a 5.0 intake on a 351w. peace
john
Black1987Stang
1,422
Jersey Shore
Sep 20, 2008
  • Sep 20, 2008
Im on the same boat as you, I'm doing the same swap and after reading tonss of different swap articles on one I've heard you can use the stock 302 p/s and a/c bracket but need to use some washers or spacers. Since the only difference I see is the deckheight and the heads are the same (head bracket holes) maybe all you need to do is drill new holes in the bracket? nay or yay? anybody got some info on this?
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
