351 swap power steering bracket install ?
power steeriig bracket
the only thing i did when I put my bracket is to cut off one of the threaded ends of one of the water pump bolts. The FMS bracket doecn't have a hole for it to fit. I have A/C. other than that it is a direct bolt on
subscribing
I may have a pic at home, but will have to wait until tonight to find it.
Hopefully someone can find one sooner.
The Aluminum casting bolts to the head. The steel stamping comes off the p/s pump and water pump.
If that makes any sense at all.:shrug:
jason
I think i will need a pic. This thing is like Chinese algebra. I feel like Ford took a hunk of metal, drilled a bunch of holes in it and wanted to see how creative I could be with it.
My AC is deleted. I think I figured it out, but the diagram i have is not showing the stock mount working with the frpp bracket. It shows that it only works with the frpp ac delete kit for a 5.0, then you swap to the 351 bracket. With the bracket installed my belt tensioner has nowhere to mount. Where should I mount the belt tensioner? My set-up may be a bit more confusing since i have a vortech s-trim and my alt mounted below on the passenger side.
