jayhawk261
I did a 351W into my 79 5.0 in about 1988. Back then there was nothing available specifically for a swap. As someone mentioned before, you need to change intake manifold, exhaust, distributor, oil pan/pickup, and your accessory brackets will have to be for the 351W as well due to the width difference. The 351 is wider and taller. As far as SD vs MAF goes, I have no idea how the SD programming would react. You can always give it a shot. Another thing you'd need to check is the flywheel balance. On a 302, the balance changed in 82 or 83 and previous to that the 302 and 351W had the same balance. I'm not sure if the late model 302 flywheel will have the same balance as the 351 or not. You'd need to verify that. The 351W cam and the 302 H.O. cam have the same firing order 1-3-7-2-6-5-4-8. The non H.O. 302 will have a different firing order than the 351. If you have an H.O. now, your firing order will be the same with respect to the computer.
ID89GT
You will need..
Swap oil pan with pickup tube, either the FRPP kit or I think out of the vans with 351w's
Swap headers
28 oz crank pulley if the engine you get don't come with one.
28 oz flywheel with 157 teeth if you are a manual.
Intake manifold
And the distributor.
Everything else will swap over from the 302.
Swap headers
Intake manifold
- Nov 10, 2009
- 312
- 0
- 0
i'm guessing i'm going to need a special tool to unhook them.
Yep. An auto parts store will carry one. I don't know if there is a way to cheat it with regular tools.
ALL of the bolts holding the valve covers on was virtually finger tight!
I think this is pretty common. Check your oil pan bolts, you'll be surprised how loose those are, too.
- Nov 10, 2009
- 312
- 0
- 0
just so people don't think he's answering a post that isn't there, i cut/pasted the rest of my last post and moved it to my "build" thread so i don't end up with too progress threads.
Nikwoac, what's the name of that tool??? i'll run by autozone tonight and see if they have one
yeah, the valve cover bolts really surprised me. i was expecting to have to struggle to get them off but i was able to back most of them off with almost no effort. i'm sure i'll come across more of the same as i go along.
I think its just called a fuel line removal tool. I don't own any myself, but I know I've seen them before at Auto Zone.
- Nov 10, 2009
- 312
- 0
- 0
- Nov 10, 2009
- 312
- 0
- 0
i just had a friend call me about a 1990 351, that is supposedly already a roller motor (not sure what that means???? HELP). I know it comes with the block and the heads (which are apparenlty NOT attached to the block) but i don't know what else ti comes with. i can apparenlty pick it up for $150. any input on this? what can i look for to see what year of block it is? what should i look for to see if its worth dragging home? ANY input would be GREATLY appreciated.
the same guy also has a '95 351. i'm about 99% sure i want to go this route over rebuilding my 302.
