- Nov 10, 2009
- 312
- 0
- 0
i'm sure this topic has been on here many times but i'm apparenlty not searching for it correctly.
i'm currently tearing down my '87 GT. i had pretty much decided to stick with the 302 and throw some bolt ons at it for good measure. but i just read a post from 90LXcoupe that really got me thinking about doing a 351 swap instead of rebuilding the 302. my BIGGEST concern is that car has to pass smog. but i would think if i used a late model engine from a pickup that wouldn't be an issue??? i haven't done any research yet to see what those motors produce out of the box but it can't be any worse than a stock 302. my car is a speed density system. will that affect the swap? are 351s just as cheap to rebuild as 302. i'm not after a high HP motor.........right now........but the 351 would leave that door WIDE open for a future build. are there aftermarket parts available for these motors as well? can any of you guys shed light on this thought process and tell me the pros and cons of going this route. i just bought an explorer upper/lower intake last night but i'll gladly resell it if my idea of going to a 351 is a valid and sound idea. would i need a different tranny setup(currently have a z-rated t-5, and centerforce clutch)? driveline issues, engine bay issues? i've noticed that most of you have gone the route of thumper 302s and i'm sure there is a reason for that instead of dropping in the 351s? HEEEELLLLPPPPPP!
