351c fuel pump help
maybenot56789
hello, i have a stupid question. i've put many fuel pumps on chevy engines, i am trying to put one on a 351c and cant find the sliding piston to lift out of the way to fit the arm of the pump under. when i place the pump into position, it will go almost all the way in, but stops about an eight of an inch short of flush. when i feel inside, all i feel is a roller type thing which just rolls, but i dont think is in the way. any tips. thanks in advance./
johnny
If I remeber correctly when I put mine together it was the same way, it dosen't fit flush untill you tighten the bolts down which can be a pain if your using short hardware as you'll have to compress the spring inside the pump in order to start the bolt in the bottom.
Ford's have a fuel pump eccentric to acctuate the pump arm. This is bolted to the front of the timing gear, and the bolt hole thru which the retainer bolt fits is offset, making the eccentric act like a cam lobe. The pump arm rides directly on the eccentric. Depending on it's position, you may have to press down on the pump body to get the pump bolts to line up. Sometimes its also possible to make the pump arm over ride the eccentric. If you're lucky the pump will slide right into place with the pump arm under the eccentric where it's supposed to be.
thanks for the tips, i was going crazy trying to find the lifter, than all the crazy thoughts were coming like did i break it off, is that the reason the pump broke in the first place....now i now better. thanks again.
johnny
