351w fuel rail questions..
  • Thread starter Thread starter ID89GT
  • Start date Start date Oct 13, 2008
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 13, 2008
  • Oct 13, 2008
Ok so am still not done with this thing..
I thought I could use the 302 fuel rails. I got new fuel line ran into between them so they would work on the wider intake and all. Well when I went to put the 351 upper plenum on, the fuel pressure regulator is in the way and doesn't work. Sooooo I went to the 351 fuel rails and am now in the problem of finding out how to run the lines to the lines that go to the tank on the car. The 351 has the quick connnects back by the firewall, while the 302 is originally on the passenger side at the front of the engine.
Black1987Stang
1,422
Jersey Shore
Oct 13, 2008
  • Oct 13, 2008
what intake are you using?
I'm doing the same thing and plan on making the lines longer on sn95 rails since theyre bigger than fox rails but don't want to go to a pricey aftermarket setup.
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 13, 2008
  • Oct 13, 2008
I just have the stock 351 intake that came on the engine
vristang
4,933
101
124
Seattle
Oct 13, 2008
  • Oct 13, 2008
While the stock 351w intakes will get the motor running, they will severly limit power... I hope a upgrade is in the plans?
I used the stock 302 rails, and widened the crossovers with standard high pressure fuel line.
What regulator are you using?
Where is the interference?
I think mine hit the EGR, but that was a long time ago....
jason
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 13, 2008
  • Oct 13, 2008
Ya I had the 302 fuel rails but when I went to put the 351 upper plenum on, it would hit the fuel pressure regulator..
Ya I have lots of upgrades in the future.. This is just to get the car going for now.
68stang351
850
9
39
Savoy TX
Oct 14, 2008
  • Oct 14, 2008
What plenum are you using?
vristang
4,933
101
124
Seattle
Oct 14, 2008
  • Oct 14, 2008
AND....
what regulator?
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 15, 2008
  • Oct 15, 2008
The stock 351 untill i buy a new one
vristang
4,933
101
124
Seattle
Oct 15, 2008
  • Oct 15, 2008
How about a pic of where the interference is?
68stang351
850
9
39
Savoy TX
Oct 15, 2008
#10
  • Oct 15, 2008
  • #10
You're using a stock 351 truck plenum?
ls1beater4eva
334
mooresville
Oct 15, 2008
#11
  • Oct 15, 2008
  • #11
why not just buy the upr fuel rail kit its cheap enough and worth the upgrade
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 16, 2008
#12
  • Oct 16, 2008
  • #12
Ya its just the stock fuel pressure regulator.
And ya im guessing its the 351 stock truck plenum, its what came with the engine. My 302 upper wont work
68stang351
850
9
39
Savoy TX
Oct 16, 2008
#13
  • Oct 16, 2008
  • #13
You need to get rid of that truck intake.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
Fuel 87 5.0 Fuel rail lines
  • Mcmahst
  • Jan 21, 2025
Fox 5.0 Mustang Tech Feb 11, 2025
Mcmahst
