I've got a 351W, bored .30 over, Edelbrock Performer RPM cam, intake and carb, Accudrive gear drive, Crane springs, Comp Cams roller rockers + a bunch of other ****. At what point do you need to change from press-in studs to screw-in studs on the heads? Also, what does it cost to have them drilled and tapped for the screw in studs? I've also heard that they need to machine some off the "pedestal" where the studs screw in due to the height of the "head" of the screws. Is this true?
huh so much for that.
