351w modifications
  • Thread starter Thread starter joarzero
  • Start date Start date Apr 12, 2004
J
joarzero
  • Apr 12, 2004
hi everybody, i need some help to make some modifications to my mustang, i want more power, its going to be a daily driver but i run the 1/4 mile sometimes, its a 1973 mach 1, standar transmission, the modifications i want are; headers, dual exhaust, a bigger carb, intake manifold, ignition, distributor, coil,what do you think or what else do you recomend, can you help my whit part numbers, brands, specifications, etc, i am not in a hurry so i am planning to buy each part at a time, thank you
SadbutTrue
2,391
Thousand Oaks, California
Apr 12, 2004
  • Apr 12, 2004
depends on what your goals are in your car, with the combo below my car could run a mid to high 14 with a posi rear and real tires (i have a 351w). Over summer, I plan on doing more aggressive things, such as ported heads (or aluminum ones if i have money), a compcams 274XE cam, 650 Holley double pumper, keep my exhaust, and a Weiand stealth... plus the MSD igntion and accel coil already on my car... should be good for 13s. Your car is a bit heavier, so you might see slightly higher times, but that gives you an idea of what mods on a 351w will do.
brianj5600
1,964
Middle TN
Apr 12, 2004
  • Apr 12, 2004
Stock cams are pathetic. No lift, no duration, no power. If it has a stock timing chain I think the cam comes retarded. That all adds up to missing hp. Pick a cam company and tell them what you have and what you want and let them help you pick one. Intake and cam are a package deal so make sure they are compatable.
J
joarzero
  • Apr 13, 2004
i dont want big modifications, i just want more power, but keeping the car streetable, i am open to opinions so lets start, thank you
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
