Hi Folks
I'm having a tough time getting the 351w in my 67 Ranchero to run. I built the engine a bit over a year ago. I've had it running roughly a couple times, but life got in the way. Now I'm motivated to get it going. To wit, I have it built with 284 Comp Cams roller cam, roller rockers, Ford billet damper, TFS heads, 4160 holley carb, performer rpm, T5, original distributor with Pertronix. Have an MSD 6AL, but it isn't installed yet.
I have fuel, I appear to have spark at least some of the time.
After I first got it running (it was running rough but sounded sweet above 2,000 rpm), I tried to time it and the strobe wouldn't light on any of the marks on the damper. The damper has two sets of timing marks, so I figured I screwed that up. I pulled the plugs and distributor, rotated the crank so that I felt air pressure coming out of cylinder 1, then continuted to rotate to the 0 degree mark on the damper. Reinstalled dist and plugs. No luck, now it won't fire at all. Tried the other set of marks - no go. I'm at my wit's end. Any suggestions? Anyone want to come to central Tucson and give me a hand?
Thanks
Steve
sstewartAThwrDOTarizonaDOTedu
Thanks
Steve
