My 302 roller started knocking very badly in october, so I parked it for the winter.
I have a 1978 351 windsor on a engine stand in my garage I want to put in there.
i want to use the 302 roller heads which have been worked, and have the 1.6 roller rockers, and larger valves than stock, with mild porting.
The 351 is not a roller engine, but I plan to modify it to be one.
I will have to drill and tap the block for the roller lifter retainer, and have the head bolt holes enlarged to 1/2 ".
I am leaving the bottom end stock, with the original pistons, 9 to 1 compression.
I will be using an older style Offenhauser intake with a 650 Holley.
I have a couple of questions for the engine guys.
Which cam would you recommend?
How long should the hydraulic pushrods be?
Do I need to use a steel distributer shaft gear ?
No, I can't afford expensive heads.
Any good input would help, thanks.
