351w question
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Jun 9, 2010
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 9, 2010
  • Jun 9, 2010
This isnt a roller motor right? They didnt start 351w rollers till 94? 351w EFI + e4od trans peace
john
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Jun 9, 2010
  • Jun 9, 2010
Roller blocks say F4TE on the side of the block by the starter I believe, they were 94-97 only.
85 Stang Man
  • Jun 9, 2010
Well I guess that answers the question that I had brewing. I picked up to two 351W motors, 1 was assembled but needs work and the other one was in pieces. They are both older, the assembled motor is from a 82 LTD, and the other one is from an older van like the picture from craigslist.
So what is better a roller motor? This is really a learning experience doing this project car and this forum has helped ALOT!
My plan was to drop the assembled motor into my 85 GT while I have the other motor built up.
tannerc91gt
2,967
234
Indiana
Jun 9, 2010
  • Jun 9, 2010
You can do a roller conversion on the older blocks but you have to run a smaller circumference camshaft and it really limits your choices. Rollers are ideal
tb9050lx
155
ct
Jun 10, 2010
  • Jun 10, 2010
or you can run the lifters with the tie bars so no reduced base circle is needed!
R
rbrackin15
  • Jun 11, 2010
you can put a roller cam in any windsor block I dont know what you douche's are talkin about.... might as well throw in some 1.7 rockers while your doing it.http://www.stangnet.com/images/smilies/Smilie_Canada_Flag.gif
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jun 11, 2010
  • Jun 11, 2010
Roller cams can use more aggressive ramp rates, which ultimately results in the ability to have a broader power band without sacrificing idle quality. In layman's terms, roller cams are better for performance builds than flat tappet cams.
I BELIEVE the only big difference between roller blocks and flat-tappet blocks is the roller blocks have deeper lifter bores than the flat-tappet blocks, because the roller lifters are physically longer. There are conversion kits out there to make FT blocks work with roller lifters.
rbonella
409
@ home
Jun 12, 2010
  • Jun 12, 2010
I would opt for a 69-74 block all day!!!! They are a lot stronger, the roller conversions are cheap and you can run any roller cam you want. I don't think the roller blocks are ideal, engine builders smile when you bring in a seasoned 69 block, mine did
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jun 12, 2010
  • Jun 12, 2010
Us "douches" know exactly what we're talking about. You can physically insert the cam into the block, yes. Try to run the roller cam with regular OEM hydraulic lifters, in a non-roller block and the lifters are going to bleed down once the oil hole is exposed because of the shorter lifter bores. You either have to run a reduced base circle cam, or run retrofit lifters. Those are the options. Keep up the attitude though, and I bet you don't last much longer than your whopping 7 posts.
R
rbrackin15
#10
  • Jun 12, 2010
  • #10
i love my attitude.
tannerc91gt
2,967
234
Indiana
Jun 12, 2010
#11
  • Jun 12, 2010
  • #11
Enjoy your stay then, it will be very short lived
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
R
351w stroked to 408 CARB
  • Ric4eyedFox
  • Mar 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2025
General karthief
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
