351w Swap Front Bracketry!
  • Thread starter Thread starter ChromdOutDubs
  • Start date Start date Mar 11, 2007
ChromdOutDubs
268
Tavares, Florida
Mar 11, 2007
  • Mar 11, 2007
OK, I'm to the point where i'm trying to round up all my front brackets that i will need for the 408 stroker. The pulleys i will be running are: Crank, Water Pump, Power Steering, and Alternator. I have a diagram of the belt routing. I really don't know what all i need. Do i need the tensioner? I see that when you remove your AC compressor that you need to move you PS Pump into its place, does this require different brackets, or do you just replace it with a idler pulley??? I know Ford Motor sports makes the 351w swap bracket for the power steering pump. http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=1400
Can someone please help me out, so many different possible ways....
BlooDReigN
283
Calgary, Alberta
Mar 11, 2007
  • Mar 11, 2007
I have the same set up on my 408. I used the stock alternator bracket/tensioner and I bought the powersteering bracket off a local guy. I bought that ford racing bracket ages ago thinking I was going to need it for my swap, but I didn't with the set up I have.
Here's some pics of my set up...
ChromdOutDubs
268
Tavares, Florida
Mar 11, 2007
  • Mar 11, 2007
You say you bought the power steering bracket on some guy. Is it special bracket, i found a bracket that Ford Racing sells that eliminates the AC compressor and move the PS pump into its location. From what i can tell your PS pump is in the stock AC compressor location, right? Here the link to what I'm talking about.
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=2424
Did you use a reverse flow water pump? And also did you have to do anything special to get all your pulleys aligned correctly. Thanks
-AJ
vristang
4,933
101
124
Seattle
Mar 11, 2007
  • Mar 11, 2007
AC/PS-
This is the only stock 5.0 accessory bracket that requires modification. The original AC pump and Power Steering pump can be reused if an FRPP bracket is used. If using Power Steering only (without A/C), the FRPP part number is M-8511-A351. For both AC and PS applications the FRPP number is M-8511-B351.
ChromdOutDubs
268
Tavares, Florida
Mar 11, 2007
  • Mar 11, 2007
vristang said:
AC/PS-
Is this bracket needed since the power steering will be getting moved up into the AC compressor's location?
-AJ
BlooDReigN
283
Calgary, Alberta
Mar 11, 2007
  • Mar 11, 2007
The bracket I have for my power steering pump is the aluminum piece shown in that ford racing link you provided. Yes, I'm using a reverse flow pump and I didn't have to do any modifications to anything to get the pulleys to line up properly.
ChromdOutDubs
268
Tavares, Florida
Mar 11, 2007
  • Mar 11, 2007
OK good, this is becoming easier than i thought. Which link are you talking about? The first one or the second one? Is this how you are routing your belts?
-AJ
BlooDReigN
283
Calgary, Alberta
Mar 11, 2007
  • Mar 11, 2007
The second one, and yes, that's exactly how I'm routing my belt.
ChromdOutDubs
268
Tavares, Florida
Mar 11, 2007
  • Mar 11, 2007
Awesome, Thanks alot for the help and quick responses. Im gonna go browse EBAY to see what I can find.
-AJ
BlooDReigN
283
Calgary, Alberta
Mar 11, 2007
#10
  • Mar 11, 2007
  • #10
No problem bud!
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
