I had a 342 but threw a rod and so now I am building a 351w. I am on a budget at the moment so I needed to start with a budget 351w. This setup has AFR 185's, 75mm, rpm intake, 30lb injectors. My original cam was a TFS 2 cam .542/.563. This cam was damaged when the rod broke. So now I need to decide what to do about a cam. I will be using 1.7 rr's. My first thought was maybe a b-303 cam. I use to have an e-303 cam but had idle issues with it. This was before I had a tweecer to adjust things. At the moment the only cam I have is a stock 5.0 cam. So what do you guys think? I dont want a cam that will run to 6500 because its a budget motor.
