Stock stroke 351w 11r combos/dyno results?
Cclaro
45
FL
I was wondering if anyone has real work dyno numbers with the 11r series of heads from trick flow on their 351/357w. I’m curious to see what the car is gonna put down once it’s back from paint and I get the drivetrain stuffed in it. Combo is:
stock block 351w (.030 over)
Stock length forged scat h beam rods
Kb hyper pistons
cam:
duration 231, 241 @50 lift .600 .600 114 Lsa
Tfs 11r 205 heads with 1.6 rr
Tfs r series carb intake converted to efi
Holley 1000cfm tb
42lb hr injectors (might go more)
10:1 compression
1 3/4 lt headers
expecting to spin it over 6500
anyone have good numbers with these heads?
Check out some stuff here:
You may find something similar.
Not a lot of 351 stuff in there but some good combos in the mix for sure! Thanks! Anyone else out there?
