i just installed 373 gears in my 1997 gt with a manual trans what do i do to get my speedo back to normal? thanks in advance
does anyone have the ford part # ? all the parts guys in my area are brain dead
how would you fix the speedo after a 3.73 swap on an 01 gt 5 speed? sorry to hi jack the thread lol ,i was just curious![]()
i tried the codd-b part # at the dealer and they say it is not a good # . any suggestions?
Speedcal is kinda expensive and you can only get it for one gear ratio. I guess using a tuner is the best idea, although that can get real expensive. I have an 03 GT with 3.73s and the speedo is off, but more importantly the odometer is off too. It sucks racking up miles a lot faster than you should be.
You have no idea what you're talking about.
A Speedcal is expensive compared to the gear but it covers ALL gear ratios. Going from 1.27-4.40, 3.08-4.10, 1.0-14.0, (some exaggeration there but trying to prove the point), It will convert your ratio. A tranny gear will only adjust from ONE gearset to another, no modifying in case you swap out your 373's for 3.90's or 4.10's. A speedcal CAN do that with no hassle at all.
Also he can't use a tuner since his car is pre-99, so that wouldn't do him a bit of good.
His only options are a speedcal or a tranny gear change, and the speedcal is more effective/accurate/cost effective in the long run.
Cost is about $80.00-$90.00 shipped.
Mine was like $75, and I can adjust for any gear ratio out there. It's a Dallas Mustang SpeedCal. Get it, don't think twice.Speedcal is kinda expensive and you can only get it for one gear ratio. I guess using a tuner is the best idea, although that can get real expensive. I have an 03 GT with 3.73s and the speedo is off, but more importantly the odometer is off too. It sucks racking up miles a lot faster than you should be.
thanks for all for the replies.. i ordered the speed cal.
