390 casting number help
  • Thread starter Thread starter mbc1967
  • Start date Start date Nov 12, 2007
M
mbc1967
Great State of Texas
Nov 12, 2007
  • Nov 12, 2007
I have a 67 mustang S code which appears to be all original. Pulled the engine and I was looking for casting numbers on the block and all I found so far is 2B9. From what I have read that means February 9, 1962. The heads are original, I think. They have a casting number C7AE-A. If anybody could help with where the casting number might be, please help.
RFMustangGT
294
Knoxville,TN
Nov 12, 2007
  • Nov 12, 2007
The heads very well could be original but the block I would lean towards no. A 1962 block would have a different engine mount than a block from 1967. your 1962 should have a 2 bolt engine mount on the sides of the block. later block would have a 4 bolt engine mount. If it is a 2B9 block with a 4 bolt engine mount, then you might have a 1972 block. the 1967 mustangs had a 4 bolt engine mount. hope this helps.
M
mbc1967
Nov 12, 2007
  • Nov 12, 2007
Ok, I went a checked all the #'s and the mount holes. There are 4 holes in the block but the mounts only had 3 holes and bolts with FOMOCO on them. I looked all over that block for a casting # and all I found was the date code W I and 2B9 the rest of the castings were in the front a 352 with a 2 on top of that I found DIF 53 and in the back were the bell housing bolts is 352- A that is all I have found on this block. The intake has # S C6AE- 9425G the exhaust manif. # C6OE-9439 and 94301-A and both heads have C7AE-A. Is there any chance they casted these blocks without part #'s or are the part #'s hidden somewere you can;t see untill you pull it apart. Thanks for all your help.
M
mbc1967
Nov 12, 2007
  • Nov 12, 2007
Well, I went to another site " S code registery" and someone was saying that a over the counter replacement block would not have a casting number on it. So mabye that is what I have, but everything else is tuning out to be corect. Let me know what you think.
9
96 DOHC Cobra
542
Cerritos, CA
Nov 13, 2007
  • Nov 13, 2007
Can you post a picture of the casting number? Maybe what looks like a "2" is actually a "7."
D
D.Hearne
11,730
south louisiana
Nov 13, 2007
  • Nov 13, 2007
You've got a later date block is all, I've run across two 390 blocks that had no casting numbers, it's not unusal. The two I had were 68 blocks. Someone replaced the original with a short block. The intake, heads and exhaust are correct for a 67.
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Take a look at my rack!
  • bicknell
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
Willybill32
C
1997 3.8l v6 timing cover mismatch *eBay guaranteed fit* haha please HELP
  • chasondragons
  • Apr 3, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 3, 2026
chasondragons
C
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
