390 Exhaust Manifolds
jackson0215
101
Ok, so stupid question.....I am looking for exhaust manifolds for my 390 (67 S Code) and the heads (C8AE-H) are 14 bolt but everything I see is 8 bolt. FPA has a set of 14 bolt headers and I may go that direction but I am also looking to keep my options open! Does it matter that the heads are 14 bolt and the manifolds are 8?
Thanks as always!
  • Sponsors(?)
bartl
218
62
West Rutland, Vermont
The reason the heads have 14 bolts is to accommodate both the GT and standard exhaust manifolds (you use one set or the other). Just look for a set of FE manifolds or headers for a Mustang and you be fine.
horse sence
That $5 hooker turn out to be a guy
Mod Dude
3,665
233
Wile Coyote's stunt double
helo i am new here but i an not new to mustangs,the a 8 bolt exhaust manifolds
were designed for the larger fords ,galaxies thunderbirds and such .they will not
fit in a mustang ,cougar, you must use the ones for 14 bolt heads as they
are designed specificly for these cars, with 428 cj heads having 16 bolts per head.
428 manifolds are available once again through many of the parts venders but
the 390s are not,afraid your next option would be headers, i have to tell you they
are not fun to instal
Thread starter Similar threads Forum Replies Date
S Should I mod the 302 or run the 390? 1965 - 1973 Classic Mustangs -General/Talk- 34
B ISO 390 4 speed parts Other Auto Tech 5
jackson0215 390 Charging Issue Classic Mustang Specific Tech 0
jackson0215 67 390 FE Alternator Issue Classic Mustang Specific Tech 2
C 1968 GT Fastback -390 install Classic Mustang Specific Tech 13
M Expired 1967 S Code 390 Gt Air Cleaner Engine and Power Adder 0
S 67 390 4speed Transmission Knock? 1965 - 1973 Classic Mustangs -General/Talk- 5
automart7 1967 Ford Mustang Gt 390 Overheating Classic Mustang Specific Tech 0
automart7 67 Ford Mustang Gt 390 Overheating Issue Classic Mustang Specific Tech 5
K 69 390 Advice 1965 - 1973 Classic Mustangs -General/Talk- 13
J Problem With My 1967 Mustang With A 390 1965 - 1973 Classic Mustangs -General/Talk- 6
Y Heh Cl Toploader In A '68 390 Gt 1965 - 1973 Classic Mustangs -General/Talk- 1
66fstbk Expired 1967 Fastback Gta 390 - Roller - Norcal Classic Mustangs For Sale 0
L 1968 S Code 390 1965 - 1973 Classic Mustangs -General/Talk- 1
master_bayshin Help Edelbrock 1406 Caddy 390 Other Auto Tech 4
NTO_GUY 69 Galaxie 500 Xl Convertable 390 Questions Other Auto Tech 3
S Electrical Help With 67 Fastback 390 Coil Classic Mustang Specific Tech 5
T 68 390 Vacuum Line Wanted Classic Mustang Specific Tech 6
F 1967/68 Mustang 390 mess, need help Classic Mustang Specific Tech 8
horse sence FE Build 428 Cj Heads On A 390 Block Classic Mustang Specific Tech 14
horse sence 442 Ci. 390 Stroker Classic Mustang Specific Tech 0
B (CA) 1988 Mustang LX 347 Stroker 360rwhp/390/rwtq Fox Body Mustangs For Sale (1979-93) 3
C What style tire should I use for my Stock 1967 GT 390 Classic Mustang Specific Tech 2
VicRattlehead 390 crankshaft... Engine and Power Adder 0
W 4 Sale 4 es 84 Wheels 220/55%390 VG Cond Wheels Tires Brakes 0
jackson0215 390 Hooker Headers Classic Mustang Specific Tech 1
J what to do ? 351/390 in a 65 vert.... Classic Mustang Specific Tech 2
M 1969 Mach 1 390 S Code Questions Regional Forums and Event Information 0
J 351W Stroker vs 390 Classic Mustang Specific Tech 35
M 69 Mach 1 – looking for answers about a 390 to 351w conversion: Classic Mustang Specific Tech 21
woodsnake ID 390 Classic Mustang Specific Tech 6
7 What's it worth... 1969 Fastback 390 auto 1965 - 1973 Classic Mustangs -General/Talk- 8
jackson0215 390 Block Spacer Classic Mustang Specific Tech 8
6 390 Engine for sale Manassas, Virginia Engine and Power Adder 0
M 1967 Mustang Coupe original 390 S Code Classic Mustangs For Sale 0
6 302 to 390 Swap - What do I Need? Classic Mustang Specific Tech 29
M 390 in a fox Fox 5.0 Mustang Tech 2
D repo 390 z bar fits way loose on pivot bushings Classic Mustang Specific Tech 8
D anyone use a lakewood bell for a 390 toploader? Classic Mustang Specific Tech 6
S FPA FE 390 Headers Engine and Power Adder 2
D 64 390 block F/S Engine and Power Adder 0
reusty2k5 looking for Black SN95 that blew my doors off on 390 (2-21-08) Regional Forums and Event Information 0
RFMustangGT 390 starting problems... Classic Mustang Specific Tech 3
E 1968 390 emblems? Classic Mustang Specific Tech 7
M 390 casting number help Classic Mustang Specific Tech 5
DarkoStoj 1967 Mustang fastback(390) and 1969 mustang fastback projects $5500 Engine and Power Adder 4
cave diver Rebuilt 390 and Top Loader 4-speed for sale Engine and Power Adder 8
ascoldasice17 410 or 390? SN95 4.6L Mustang Tech 18
P NEED SOME SUGGESTIONS ON REAR SWAY BAR FOR 69 MACH 1 390 Classic Mustang Specific Tech 0
B tremec tranny and 390 engine Classic Mustang Specific Tech 4
