3g alt=hotter engine temp
  • Thread starter Thread starter flashback87
  • Start date Start date Jul 14, 2010
flashback87
345
Cleveland, OH
Jul 14, 2010
  • Jul 14, 2010
hey guys, after i installed my 3g my engine temp is a little hotter. it was right about 190ish before i did the swap and now it is between 198-200. would the alternator cause this?
i have an after market temp gauge and i am running a taurus fan on high at all times.
thanks for the help.
HISSIN50
34
129
Jul 14, 2010
  • Jul 14, 2010
Did you have the Taurus fan before the 3G swap?
Is there any issue with the belt routing or did the alt pulley diameter change drastically?
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jul 15, 2010
  • Jul 15, 2010
I wouldn't think so... Wonder if the change in pulley size makes the water pump turn slower.. It's only 10 degrees I wouldn't worry about it..
flashback87
345
Cleveland, OH
Jul 15, 2010
  • Jul 15, 2010
thanks for the replies,
my tarus fan was on before the 3g install and that is when it was running a little cooler. i have always been running under drive pullies and when i did the 3g install the new alt pulley was about the same size as my u/d alt pulley so i did not swap them(i left the 3g alt pulley on)
i did have to go with a shorter belt since the original was squealing like crazy when i did the 3g swap. the new belt is only about .5 an inch smaller and it is routed the same.
any other help or advise would be greatly apreciated.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jul 15, 2010
  • Jul 15, 2010
As long as the WP and crank pulleys stayed the same size, WP speed shouldn't change. Belt length wouldn't cause a change in speed of anything either. The only thing that would change if the alt pulley diameter changed is alt speed, but it sounds like that didn't change either.
flashback87
345
Cleveland, OH
Jul 16, 2010
  • Jul 16, 2010
any other ideas or is this just normal. i feel like i finally got my car to run at the right temp but ever since the 3g it has been getting hotter but it has been staying right at 200.
HISSIN50
34
129
Jul 16, 2010
  • Jul 16, 2010
An alt should not cause the car to run hotter, so it's not normal. Either it's coincidence with warmer ambient temps or something else changed.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jul 18, 2010
  • Jul 18, 2010
Mechanical or Electrical temp gauge?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 18, 2010
  • Jul 18, 2010
If the secondary power ground (engine to body ground) is bad, the stock electric temp gauge reading will be incorrect. The engine to body ground is also the ground for the electric temp gauge.
The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
Any car that has a 3G or high output current alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects. The 3G has a 130 amp capacity, so you wire the power side with 4 gauge wire. It stands to reason that the ground side handles just a much current, so it needs to be 4 gauge too.
The picture shows the common ground point for the battery & extra 3G alternator ground wire as described above in paragraph 2. A screwdriver points to the bolt that is the common ground point.
The battery common ground is a 10 gauge pigtail with the computer ground attached to it.
Picture courtesy timewarped1972
Correct negative battery ground cable.
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
  • dan50
  • Jul 18, 2026
dan50
