Hey everyone, well, put my extra discount to work and bought a 3G alt this week, picked up a socket for it and I'm getting ready to instal it. I have the diagram from the Bronco site Bronco Link , I'm just not sure how to apply it to my mustang.
Out of the voltage regulator I have three terminals wired. F, S, and A
F- Orange
S- Light green/Red stripe
A- 2 yellow, one of which goes to a condensor sharing a mounting hole with the VR.
Can anyone tell me what wires go where? As far as I can tell from the Bronco diagram... The orange wire will be capped off, the green/red one will run to the I terminal on the new alt, the yellow will just run to the + side of the solonoid. Is this right? Or should the green/red be capped off and the orange wired in... it is a higher guage wire?
Also two more questions... 1. I have a pertronix unit on my distributer and I wanted to know i I still needed to use that condensor? and 2. For those of you who did it, how did you hook up the 175amp fuse? Did you just put one end of the fuse on the + terminal of the solonoid and a small nut and bolt on the other end to the wire? Or what? I was thinking about using a later model Gm wire box... I've seen it on a bunch of GMs. I'm just not sure if it is a junction, or meant to hold a fuse like that.
Thanks a lot everyone,
THe Swede
F- Orange
THe Swede
